DCS-6817EOL EOS
High Speed Dome Network Camera with 30X optical Zoom
Kur iegādāties
Apraksts
The D-Link DCS-6817 is a high-performance high speed dome network camera, ideal for business IP surveillance applications. The DCS-6817 employs Sony 1⁄4” Super HAD-II CCD technology to deliver exceptional picture quality. High-performance SoC (system-on-chip) technology provides real-time video compression in H.264, MPEG-4, and Motion JPEG formats.
Proportional Pan, Tilt, and Zoom Speeds
Adjusting the camera is painless since the pan and tilt speed is proportional to the optical zoom ratio of the camera. When the camera zooms in, the panning speed is automatically slowed to improve camera tracking and controllability. PTZ presets allow the camera to monitor specified areas along predefined paths.
Weatherproof for Outdoor Use
The DCS-6817 camera apparatus is housed in a weatherproof enclosure (IP66 standard). A built-in heater and fan allows camera to operate in extreme environments at temperatures ranging from -40 to 50 °C.
Removable IR Cut Filter for Continuous Monitoring
The IR Cut Filter can be manually applied, or set to automatically adjust based on lighting conditions. This feature enables the camera to capture crisp color images during the daytime, and grayscale images in low-light.
Wide Dynamic Range (WDR) Applications
The Wide Dynamic Range (WDR) function of a camera provides clear images even under backlit conditions where the intensity of illumination can vary significantly. The DCS-6817 is recommended for extreme high-contrast environments. For example, when placed indoors, the DCS-6817 will adjust itself to the intense sunlight that may be streaming in through a nearby window. This makes it an ideal solution for security applications.
Robust Management Software
D-ViewCam is a software program that allows you to view up to 32 cameras on a single computer screen from a central location. Motion detection and digital input devices trigger automated e-mail alerts that can instantly inform administrators of unusual activities.
Īpašības
Camera Hardware Profile
• Sony Super HAD-II 1/4” CCD sensor
• Minimum illumination 0.1 lux (Color); 0.01 lux (B/W)
• Optical Zoom: 30X
• Focal length: 3.4 to 102 mm
• Angle of View (Horizontal): 2.2° to 60.8°
• 650 TVL
• Built-in Infrared-Cut Removable (ICR) Filter module
• S/N ratio > 50 dB (AGC off)
• Electronic shutter 1/1 to 1/10K sec.
• 1-12x variable digital zoom
PTZ Hardware Profile
• Pan travel: 360° endless
• Tilt Travel: -10° to 190°
• Manual Speed: 0.5° to 90°/s
• Presets: 256 points
• Preset Accuracy: 0.225°
• Preset Speed: 5° to 400°/s
• Sequence Paths: 8
• Auto Pan Paths: 4
• Cruise Paths: 8
• Pan and tilt speed proportional to zoom ratio
• Resume after Power loss
• Home Function: Preset, Sequence, Auto pan, Cruise
• Auto Flip: Mechanical/Digital/Off
• Digital Slow Shutter
• Image Freeze
• Image Inverse
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 16 configurable privacy mask
• Configurable white balance, shutter speed, brightness, saturation, contrast, sharpness
Video Compression
• Simultaneous H.264/MPEG4/MJPEG format compression
• JPEG for still images
Video Resolution
NTSC Support:
• Up to 30 fps at 176 x 120
• Up to 30 fps at 352 x 240
• Up to 30 fps at 720 x 480
PAL Support:
• Up to 25 fps at 176 x 144
• Up to 25 fps at 352 x 288
• Up to 25 fps at 720 x 576
Audio Support
• 2-way audio support with G.726 compression
External Device Interfaces
• 10/100 BASE-TX Ethernet port
• 8 Alarm inputs
• 1 Alarm output
• Audio input / output
• Video output
Network Protocols
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP / HTTPS
• Samba Client
• PPPoE
• UPnP Port Forwarding
• RTP / RTSP/ RTCP
• IP filtering
• 3GPP
• IGMP
• ONVIF Compliant
Security
• Administrator and user group protection
• Password authentication
System Requirements for Web Interface
• Operating system: Microsoft windows, 2000, XP, Vista, 7
• Browser: Internet explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Multiple event notification
• Event notification and upload snapshots/video clips via HTTP, SMTP or FTP
• Supports multiple HTTP, SMTP and FTP servers
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
Mobile Support
• Windows 2000 / XP / Vista / Win 7 / Pocket PC / Mobile Phone which 3GPP
D-ViewCam System Requirements
• Operating System: Microsoft Windows 7 / Vista / XP
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion triggered, or manual recording options
Physical Parameters
Power Input
• AC 24 V / 3 A
Max. Power Consumption
• Max 65 W (with heater)
Dimensions
• Height: 302.5 mm
• Diameter: 190 mm
Weight
• 2.6 kg
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% (Non-condensing)
Certifications
• CE (Class A)
• CE LVD (EN60965-1)
• FCC (Class A)
• ICES-003
• C-Tick
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DCS-6817  High Speed Dome Network Camera with 30X optical Zoom
Attēli
DCS-6817
Skatiet arī
