DCS-5230LEOL EOS
Pan & Tilt Wireless N Network Camera
Kur iegādāties
Apraksts
Full-featured wireless surveillance camera
D-Link DCS-5230L Pan & Tilt Wireless N Network Camera is a pan and tilt wireless network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. It gives you detailed remote surveillance of a large area by using a 1.3 megapixel CMOS image sensor for high-quality video and a built-in IR illuminator for low-light surveillance. The DCS-5230L can also be connected to your network wirelessly, allowing you to place the camera anywhere, and eliminating the need to install network cabling.
A Complete Surveillance System
The DCS-5230L includes a built-in CPU, allowing it to be used as a complete, standalone surveillance system. Recordings can be made continuously, whenever movement is detected, or according to a schedule you define. E-mail notifications can be sent when specific events occur, keeping you informed of what’s going on. The built-in microSD slot allows the camera to run independently, or can be used to continuously record video even if the network connection is lost. The DCS-5230L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports up to 32 cameras.
Sharp image monitoring from different angles
With sharp, responsive pan/tilt movement and digital zoom, the D-Link Pan & Tilt Wireless N Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and 16x digital zoom lets you zoom in for more detail.1 The DCS-5320L can also be set to automatically move to specific preset positions, allowing the camera to patrol and secure a wide area.
MyDLink for easy setup and remote viewing on your phone
D-Link’s convenient mydlink™ zero-configuration setup gets you up and running in no time – just connect the DCS-5320L, then register the device on the mydlink™ website. The DCS-5320L will then automatically configure itself and connect to the mydlink™ service, which gives you convenient access to your video feeds through the mydlink website. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps so you can stay in touch on the go.
Īpašības
Camera specifications
• 1.3 megapixel 1/3” CMOS sensor
• Standard fixed mount type 3.98 mm lens, F2.0  AGC/AWB/AES
• Electronic shutter: 1/60 to 1/15000 sec.
• 62˚ field of view
LED indicators ƒ
• Link/Power ƒ
• WPS
Reset button
• Reset to factory default settings
Video features
• Adjustable image size and quality ƒ
• Time stamp and text overlays
• Three configurable motion detection windows ƒ Flip & mirror
Video Algorithm Support
• JPEG for still images
• Enhanced video compression using MPEG4 Simple Profile
• MPEG4/MJPEG dual format compression
VIDEO RESOLUTION
• VGA (640 x 480)
  ­ 640 x 480 at 30 fps
  ­ 320 x 240 at 30 fps
  ­ 160 x 120 at 30 fps
• XGA (1024 x 768)
  ­ 1024 x 768 at 10 fps
  ­ 512 x 384 at 10 fps
  ­ 256 x 192 at 10 fps
• SXGA (1280 x 1024)
  ­ 1280 x 1024 at 10 fps
PAN/TILT/Zoom
• Pan Range: -180° to 130°
• Tilt Range: -85° to 5°
• Digital Zoom: 16x 2
Microphone
• Omni-directional
• Frequency 20 to 20,000 Hz
• S/N ratio: over 58 dB
AUDIO Sampling Rate:
• GSM-AMR: 12.2 Kbps
• PCM: 8 Kbps
Radio and Modulation Schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
• 802.11b: DQPSK, DBPSK and CCK
Operating Frequency
• 2400 to 24835 MHz
Wireless Data Rates
• IEEE 802.11n: Up to 300 Mbps
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps  IEEE 802.11b: 11, 5.5, 2 and 1 Mbps
Receiver Sensitivity
• 802.11b:
 11 Mbps (CCK): -84 dBm
 5.5 Mbps (CCK): -86 dBm
 2 Mbps (DQPSK): -88 dBm
 1 Mbps (DBPSK): -90 dBm
• 802.11g:
 54 Mbps (OFDM): -66 dBm
 48 Mbps (OFDM): - 70 dBm
 36 Mbps (OFDM): -76 dBm
 24 Mbps (OFDM): -79 dBm
 18 Mbps (OFDM): -83 dBm
 12 Mbps (OFDM): -85 dBm
 9 Mbps (OFDM): -86 dBm
 6 Mbps (OFDM): -86 dBm
Transmitter Output Power
• 802.11n: 12 dBm (typical)
• 802.11g: 12 dBm (typical)
• 802.11b: 16 dBm (typical)
Antennas
• 2 dBi Gain dipole antenna with reverse SMA plug
• Operating Frequency: 2.4 Ghz
NETWORK INTERFACE
• IEEE 802.11n
• 10/100BASE-TX Fast Ethernet with auto-MDI/MDIX support
NETWORK PROTOCOL SUPPORT
• IPv4, ARP, TCP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP Server, PPPoE, RTP, RTSP, RTCP, 3GPP
REMOTE MANAGEMENT
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive via web browser
SECURITY
• Administrator and user group protected  Password authentication  WPA2/WPA-PSK/WEP(64/128-bit) wireless encryption
SurveilLance
• Record video continuously
• Record video according to a weekly schedule  Record video when motion is detected  Upload snapshots/video clips via e-mail  Upload snapshots/video clips via FTP
System requirements
• Operating System: Microsoft Windows 7/Vista/XP SP3, Mac OS X 10.3 or higher, Linux
• Browser: Internet Explorer 6 or higher
Suported Mobile Devices
• Mobile devices with a 3GPP player, such as Packet Video Player 3.0, QuickTime 6.5, or Real Player 10.5
• mydlink app requires a mobile device running iOS or Android
POWER INPUT
• 12 V / 1.25 A switching power adapter  External AC-to-DC switching power adapter
POWER CONSUMPTION
• 6 watts maximum
DIMENSIONS (L x W x H)
• 110 x 105 x 112 mm (4.33 x 4.13 x 4.41 inches)
WEIGHT
• 393 grams (0.87 lb)
OPERATION TEMPERATURE
• 0 to 40 ºC (32 to 104 ºF)
STORAGE TEMPERATURE
• -20 to 70 ºC (-4 to 158 ºF)
HUMIDITY
• 20% to 80% non-condensing
CERTIFICATIONS
• FCC Class B  IC
• CE  C-Tick
• EN 300 328-2 (07-2000)
• EN60950
Package Contents
• DCS-5230L camera
• External power adapter
• CAT5 Ethernet cable
• Quick Installation Guide
• Master CD
• Camera stand
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
Attēli
DCS-5230L
Skatiet arī
