DNR-322LEOL EOS
mydlink Network Video Recorder
Apraksts
	Convenient and reliable video recording
	The DNR-322L mydlink network video recorder is a standalone storage device that can record video from up to nine network cameras to a dedicated HDD storage without requiring users to turn on their PC. Empowered by mydlink technology, DNR-322L supports real-time remote monitoring and playback via a web browser using the mydlink website or the NVR’s web GUI. The DNR-322L has the ability to continue recording live while a user is viewing or searching footage at the same time. With complete video management, the DNR-322L’s display and playback ability make it a convenient and effective video recorder.
	Versatile monitoring adjustment
	Users are provided with a variety of options for viewing and organizing camera footage on-screen. For a system with multiple channels, users can simply drag and drop selected cameras to the viewing area. Camera names and recording statuses are displayed via the on-screen display. A single camera may beviewed full-screen with two-way audio support. Users can control pan/tilt/zoom (PTZ) functions from within the interface or by directly clicking on the video.
	Secure storage
	Administrators may filter external connections to the NVR by IP address, limiting access and thus increasing security. Administrators may also choose access privileges for users by specifying the cameras they may access. The recorded data can be backed up to additional storage locations periodically or whenever needed. The NVR also includes the option to protect data using a RAID 1 configuration, which duplicates recorded data onto two separate hard drives. In the event of HDD failure, data integrity is maintained on the secondary HDD. The secondary HDD can also be formatted as a file server and mounted to your Windows system as a network drive.
	Extensive recording functionality
	The DNR-322L’s clear interface allows for easy configuration including compression, resolution, and frame rate for all connected cameras. Once the cameras have been set up, recordings can be made continuously, or according to a user-defined schedule. The NVR also provides event recording based on specific triggers such as when motion is detected.
Īpašības
	Software specifications
	OS
	• Linux
	Supported cameras
	• Supports all D-Link network cameras. Includes support for auto-discovery, and up to 3 megapixel resolution.
	Recording performance
	• Max. capacity (NVR mode only):
	  H.264 1080P (bitrate): 90 Mbps
	  H.264 720P (bitrate): 90 Mbps
	  MJPEG 1080P (frame rate): 90 fps
	  MJPEG 720P (frame rate): 192 fps
	• Max. capacity (NVR + File Server mode):
	  H.264 1080P (bitrate): 68 Mbps
	  H.264 720P (bitrate): 68 Mbps
	  MJPEG 1080P (frame rate): 70 fps
	  MJPEG 720P (frame rate): 150 fps
	Camera Search
	• UPnP
	Audio and video recording
	• Synchronized audio & video recording
	Compression Format
	• H.264, MPEG-4, M-JPEG (for supported cameras)
	Video settings
	• Resolution, quality, frame rate, enable audio, go to camera interface
	Recording type
	• Record by schedule, manual, and event-based recording
	• Motion-triggered recording
	Remote live view
	• Supported via Internet Explorer (max. 9 simultaneous channels)
	• Supports mydlink portal (max. 1 simultaneous channel)
	Remote live view control
	• Live view, preset/go, patrol, focus, PTZ functions, snapshot, full
	screen, digital zoom, e-map, multiple view (1/4/6/9/16/25/36/48) with duplicated carrier
	Remote playback control
	• Playback with normal, fast forward/rewind and step forward/rewind
	Remote playback
	• Supported via Internet Explorer and NVR client
	• Playback system with timeline GUI, search by event, area, cameras, date and time
	• IE and NVR client support 1-channel
	• Digital zoom
	Overwrite recording
	• Auto recycling when disk storage is full
	File export
	• Export videos to AVI or ASF file
	• Export images to BMP and JPG file
	User account
	• Additional accounts can be created to allow user access to the system, and specify authorization for camera channels, PTZ, etc
	System time
	• Set the system time (D-Link NTP, input time, sync with your computer, Daylight Saving Time)
	DDNS
	• D-Link DDNS server support
	Remote backup
	• Remote software can backup raw data to redundant storage
	• Auto backup of previous day's video to FTP server
	System status
	• Camera status, system status
	• Still picture EMAP support
	Network protocols
	• IPV4, ARP, TCP, UDP, ICMP
	• DHCP Client
	• NTP Client (D-Link)
	• DNS Client
	• DDNS Client (D-Link)
	• SMTP Client
	• HTTP Server
	• PPPoE
	• UPnP
	• IP filtering
	User interface
	• mydlink web portal - Internet Explorer 7 or newer
	• HTTP Web browser - Internet Explorer 7 or newer (32 bit OS only)
	• NVR Search Utility
	Hardware specifications
	Standards
	• IEEE 802.3/u/z
	• Auto MDI/MDI-X
	• SATA I, II
	HDD (Hard Disk Drive)*
	• Hard disk control & management via PC
	• Reformat disk
	• RAID 0**
	• RAID 1**
	• JBOD
	Two reset modes
	• Reset firmware GUI button
	• HW reset button (hold for 5 seconds)
	Flash ROM
	• 128 MB
	RAM
	• 128 MB DDR II
	Network interface
	• Gigabit Ethernet LAN port (10/100/1000 Mbps)
	I/O Ports
	• RJ-45 port
	• DC-in jack
	• USB port for UPS status update (optional)
Sertifikāti
Informācija pasūtījumam
DNR-322L mydlink Network Video Recorder
