Ātrā meklēšana
Produkta iespējas:
D-ViewCam Video Management Software
Īpašības:
Camera Support
• Supports up to 32 cameras
• Megapixel network camera support
Video Compression
• MJPEG/MPEG-4/H.264 compression format
Software Features
• OSD (On-screen Display) setting
• Live monitoring
• 30 FPS maximum recording per camera (subject to camera and video server capacity)
• Automatic discovery of network cameras
• Multilingual support
• On-the-fly configuration changes
• E-mail notifications
• Lock system to avoid unauthorized changes
System User Management
• User Validation
• User Password Restriction
• User Profiling
• Access Privilege Control
Recording
• Supports multiple storage locations
• Record by schedule
• Record by event
• Digital watermark protection
• Pre-record/Post-record support
• Manual recording support
• One-way audio recording of multiple channels
• Record and live display at different frame rates and resolution
Data Search and Playback
• Video playback control
• Histogram quick search method for videos
• Video stamp
• Extract snapshots from video
• Extract video to AVI/ASF
• Supports remote playback/web playback
Video Mode
• Screen division layout support
• Monitor display allows for drag and drop of videos
• Supports full screen video
• Information window support
• Enable Move function to control a P/T/Z camera
• Digital zoom in/out support
• Duplicate camera
• Supports remote live viewing to display video
Map Mode
• Multiple map support
• Alarm notification
• Customized map background support
• Camera preview
• Camera and I/O indicator
PTZ Control
• Auto Pan
• Manual control
• Preset positions (device dependent)
• Preset patrolling
• Multiple patrol group support
I/O Feature
• Output port control
• Input port trigger on event
• Output port relay when an event is detected
Backup
• Backup database for logs and videos
• Import/Export configuration
• DB tool
• Burn backup files to DVDs on Windows XP
Minimum System Requirements*
• CPU: Intel Core 2 Duo E5300
• RAM: 2 GB
• Motherboard: Intel P55, H55, X58, P45, P43 chip, MB vendor ASUS Gigabyte or MSI with Intel Chipset recommended
• Video card: ATI Radeon 4650 or above (ATI Driver V11-2 recommended)
• Ethernet: 100Base-T or above, Gigabit LAN recommended
• Hard Disk**: 250 GB or above
• Operating system:
  32 bits: MS Windows XP pro SP3/ Vista SP1/ Win 7 SP1/ Win 8
  64 bits: Win 7 SP1/ Win Server 2008 R2/ Win 8, Win Server 2012
* To determine the minimum hardware requirements for your planned surveillance system if it is not listed in the above table, please consult the SI (system integrator), the reseller, or D-Link Technical Support.
** Recording video over a long period of time will consume large amounts of disk space. Make sure that you have enough disk space if you want to use the recording function.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
