DCS-6314EOL EOS
Full HD Outdoor Fixed Dome Network Camera
Apraksts
	The D-Link DCS-6314 Full HD Outdoor Fixed Dome Network Camera is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity megapixel progressive scan CMOS sensor with onboardWDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one
	rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for accessories.
	High-Quality Video
	To maximize bandwidth efficiency and improve image quality, the DCS-6314 provides real-time video compression using the H.264, MPEG-4, and MJPEG codecs, and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory.
	Continuous Monitoring
	The DCS-6314’s WDR image enhancement gives you improved image quality in environments with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly lit areas. In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-6314 also has built-in IR LED illuminators with a 15 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day.
	Robust Management Software
	The DCS-6314 Full HD Outdoor Fixed Dome Network Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
	Flexible Connectivity
	The DCS-6314 has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
Īpašības
	Camera Hardware Profile
	• 1/2.8" 2 Megapixel progressive CMOS sensor
	• 15 meter IR illumination distance
	• Minimum illumination 0.2 Lux / F1.4 Color mode
	• Minimum illumination 0.05 Lux / F1.4 Black and White mode
	• Minimum illumination 0 Lux Black and White mode with IR LED on
	• Removable (ICR) Filter module
	• 2.8 to 12mm variable focal lens
	• Aperture F1.4
	• Minimum object distance 0.2M (wide 2.8mm)
	• Angle of view (16:9)
	  (H) 96.5° ~ 31.2°
	  (V) 64.5° ~ 17.8°
	  (D) 117.5° ~ 36.8°
	• 3-Axis Adjustment
	• Pan 340°
	• Tilt 75°
	• Rotational 300°
	Camera Housing
	• IP68 compliant weatherproof housing
	• IK-10 compliant vandal-proof housing
	• Included weather shield
	Image Features
	• Configurable image size, quality, frame rate, and bit rate
	• Time stamp and text overlays
	• Configurable motion detection windows
	• Configurable privacy mask zones
	• Configurable exposure time, brightness, saturation, contrast, contrast, sharpness
	Video Compression
	• Simultaneous H.264/MPEG-4/MJPEG format compression
	• H.264/MPEG-4 multicast streaming
	• JPEG for still images
	Video Resolution
	• 16:9 - 1920 x 1080, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps
	• 4:3 - 1440 x 1080, 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 fps
	Audio Support
	• G.726
	• G.711
	External Device Interface
	• 10/100 BASE-TX Ethernet port with PoE
	• 1 DI / 1 DO
	• DC12 V, 100 mA Output
	• micro SD/SDHC card Slot
	• Audio input / output
	Network Protocols
	• IPv6
	• IPv4
	• TCP/IP
	• UDP
	• ICMP
	• DHCP client
	• NTP client (D-Link)
	• DNS client
	• DDNS client (D-Link)
	• SMTP client
	• FTP client
	• HTTP/HTTPS
	• Samba client
	• PPPoE
	• UPnP port forwarding
	• RTP/RTSP/RTCP
	• IP filtering
	• QoS
	• CoS
	• Multicast
	• ONVIF compliant
	Security
	• Administrator and user group protection
	• Password authentication
	• HTTP and RTSP authentication
	System Requirements for Web Interface
	• Browser: Internet Explorer, Firefox, Chrome, Safari
	Event Management
	• Motion detection
	• Event notification and uploading of snapshots/video clips via e-mail or FTP
	• Supports multiple SMTP and FTP servers
	• Multiple event notifications
	• Multiple recording methods for easy backup
	Remote Management
	• Take snapshots/video clips and save to local hard drive via a web browser
	• Configuration interface accessible via web browser
	OS Support
	• Windows 8, 7, Vista, 2000, or XP
	D-ViewCam™ System Requirements
	• Operating System: Microsoft Windows 8, 7, Vista, or XP
	• Web Browser: Internet Explorer 7 or higher
	• Protocol: Standard TCP/IP
	D-ViewCam™ Software Functions
	• Remote management/control of up to 32 cameras
	• Supports all management functions provided in web interface
	• Viewing of up to 32 cameras on one screen
	• Scheduled motion triggered, or manual recording options
Sertifikāti
Informācija pasūtījumam
