DCS-825L
Wi-Fi Baby Camera
Kur iegādāties
Apraksts
Keep an eye on your little one with the DCS-825L Wi-Fi Baby Camera. This portable camera transforms your mobile device into a versatile, yet easy to use baby monitor. Connect to the camera wirelessly or through the Internet so you can check on your infant no matter where you are. It includes a wide array of features to help you care for your child, including motion, sound, and temperature monitoring help you watch over your child, as well as night vision, automatic snapshots and recording. It can even play gentle lullabies to help ease your baby to sleep!
Peace of Mind, Anywhere, Anytime
The Wi-Fi Baby Camera is specially designed to make it easy for you to care for your baby. You get a sharp 720p HD picture thanks to the megapixel camera sensor, and night vision mode turns on automatically when it gets dark, so you can monitor your child day or night. It’s perfect for use in the home, or even when you’re away; it’s mydlink- enabled, which means that you can check on your baby remotely through the Internet.
Sophisticated Technology to Keep You Informed
The Wi-Fi Baby Camera can send you notifications to alert you to specific events. A temperature sensor constantly monitors the room temperature, and alerts you when the room becomes too hot or too cold to ensure that your child is safe and comfortable. It can also detect movement and loud noises such as crying, and this can trigger recording of snapshots and video clips that you can review later.
Perfectly Portable for Instant Monitoring Anywhere
You can take the Wi-Fi Baby Camera with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the Wi-Fi Baby Camera’s wireless network for instant local monitoring, making it perfect for family vacations or just visiting friends. You can even connect it to an external USB battery* for total portability!
Super Simple to Use
Getting started is a snap; the free mydlink Baby app for iPhone, iPad, and Android mobile devices not only guides you step by step through the setup process, but also gives you an easy to use interface for all the advanced features of the Wi-Fi Baby Camera. Check on your baby at a glance, pinch to zoom in and out with ease, or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
Īpašības
Hardware profile camera
• 1/4-inch megapixel progressive CMOS sensor
• IR light illumination distance: 5m
• Minimum illumination: 0 lux with IR LEDs on
• Built-in microphone and speaker
• Digital Zoom
• Tripod screw mount
• Focal length: 3.3mm
• Aperture: F2.2
• Angle of view:
  • 66.18° (H)
  • 35.9° (V)
  • 76.22° (D)
External device interfaces
• 802.11n wireless
• microSDHC card slot**
• Reset button
• Lullaby, Volume Up/Down, Power buttons
• Power port (Micro-USB)
Image features
• Configurable image size
• Time stamp and temperature overlays
Video Compression
• Compression H.264 video
• JPEG for still images
Video Resolution
• 1280x720
• 640x360
Audio support
• AAC
Baby monitoring features
• Sound detection with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Record snapshots and video to microSD card when triggered by motion or sound
• Temperature detection with configurable alert range
• Sends notifications when sound/motion/temperature change is detected
• 2-way audio lets you listen and respond to your child
Mobile App
• mydlink Baby Camera Monitor app available on the App Store® and Google Play™
• Compatible with iPhone and iPad using iOS 5.1.1 or higher
• Compatible with Android smartphones and tablets using Android 4.01 or higher
Network protocols
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• HTTP
• HTTPS (for configuration)
• UPnP Port Forwarding
• RTP/RTSP/RTCP
Security
• Administrator protection
• Password authentication
• HTTP and RTSP authentication
System requirements for the web interface
• Operating System: Microsoft Windows XP, Vista, 7, 8
• Web browser: Internet Explorer version 7 or higher, Firefox, Chrome, Safari
Fiziskie raksturlielumi
Measurements
• 137.1 x 92 x 105.5mm with temperature sensor fully extended
Weight
• Device: 139.6g
Power input
• 5VDC/1.5A, 50/60Hz through power adapter
• Can be powered by an external USB battery with at least output 2A output
Power consumption
• 7.5W max.
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
* USB battery not included, requires at least 2 A output.
** A SDHC Class 6 or above is recommended. Supports card capabilities up to 32GB.
Sertifikāti
Informācija pasūtījumam
Attēli
DCS-825L
Вид сзади
Вид сзади
Skatiet arī
