Ātrā meklēšana
Produkta iespējas:
Vigilance Full HD Outdoor Vandal-Proof PoE Dome Camera
EOL
Īpašības:
Camera
• 1/3” Megapixel progressive CMOS sensor
• 20 meter IR illumination distance
• Minimum illumination:
  • 1.0 lux / F2.0 (color)
  • 0.5 lux /F2.0 (B/W)
  • 0 lux / F2.0 (IR-LED on)
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Minimum object distance 0.2M
• Focal length: 2.8 mm
• Aperture: F2.0
• Angle of view:
  • (H) 96°
  • (V) 54°
  • (D) 108°
• Adjustment angle (non-motorized):
  • Vertical: 60°
  • Horizontal: 350°
Camera Housing
• IP-66 compliant weatherproof housing
• IK10 vandal-proof housing
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Configurable privacy mask zones
• Time stamp and text overlays
• Configurable shutter speed, brightness, saturation,
• Configurable motion detection windows    contrast, sharpness, WDR, and 3D filter.
Video Compression
• Simultaneous H.264/MJPEG format compression
• JPEG for still images
• H.264/MJPEG multicast streaming
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360, 480 x 272, 320 x 176 up to 30 fps
• 4:3 - 1440 x 1080, 1280 x 960, 900 x 720, 800 x 592, 640 x 480, 480 x 352, 320 x 240 up to 30 fps
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port
• Supports 802.3af PoE Class 2
Network
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• Multicast
• CoS
• QoS/DSCP
• SNMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Management
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive accessible via web browser
• Configuration interface
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista
• Protocol: Standard TCP/IP
• Web Browser: Internet Explorer 7 or higher
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Weight
• 525 g ± 5%
Power
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V DC 1.5 A
Power Consumption
• 5.5 watts ± 5% (PoE)
Temperature
• Operating: -30 to 50 °C (-22 to 124 °F)
• Storage: -20 to 70 °C (-4 to 158 °F)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• FCC
• CE LVD
• C-Tick
Dimensions
size
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
