DCS-4603
3 Megapixel Vigilance PoE Dome Camera
Kur iegādāties
Apraksts
The D-Link DCS-4603 camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 1/3” 3 megapixel progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for additional accessories.
High-Quality Streaming & Recording
To maximize bandwidth efficiency and improve image capture, the DCS-4603 supports real-time video compression using the H.264 and MJPEG codecs, providing the highest quality and video recording possible. Separate profiles for simultaneous video streaming and recording allows for a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory.
Flexible Connectivity
The DCS-4603 has a built-in 802.3af-compliant PoE module that simplifies installation by providing power and networking connectivity over a single cable, reducing the need to install additional cabling. Optional mounting hardware is also available for applications and environments that require special mounts for the most effective surveillance of any area.
Versatile Monitoring Options
The DCS-4603’s Wide Dynamic Range image enhancement gives you improved image quality in
environments with uneven or difficult lighting, so you can identify subjects that are backlit or
in brightly lit areas. In low-light situations, the IR-cut filter automatically slides out of the way to use all available light. The DCS-4603 also has built-in IR LED illuminators with a 10-meter range, allowing the camera to keep watch even in complete darkness. These features work together to provide a reliable surveillance camera capable of monitoring an area 24 hours a day.
Robust Management Software
The DCS-4603 camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
Īpašības
Hardware Profile
• 1/3” 3 Megapixel progressive CMOS sensor
• Built-in Infrared-Cut Removable (ICR) filter module
• Minimum illumination:
  Color (Day Mode): 0.5 lux
  B/W (Night Mode), IR LEDs off: 0.25 lux
  B/W (Night Mode), IR LEDs on: 0 lux
• IR illumination distance: 10 m
• Focal length: 2.8 mm
• Minimum object distance 0.2 m
• Aperture: F2.0
• 10x digital zoom
• Angle of view (16:9):
  (H) 84°
  (V) 48°
• Adjustment angle (non-motorized):
  Vertical: 340°
  Horizontal: 60°
  Rotation: 340°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, sharpness, WDR, and 3D filter
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolutions
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360 up to 30 fps
• 4:3 - 2048 x 1536 up to 15 fps, 1440 x 1080, 1280 x 960, 900 x 720, 800 x 592, 640 x 480 up to 30 fps
External Device Interface
• 10/100 BASE-TX Fast Ethernet port
• Supports 802.3af PoE Class 2
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• Multicast
• CoS
• QoS/DSCP
• SNMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
D-ViewCam System Requirements
• Operating System: Microsoft Windows 8/7/Vista
• Web Browser: Internet Explorer 7 or higher
• Protocol: TCP/IP
D-ViewCam Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Weight
• 385 g ± 5%
Dimensions
• Diameter: 110.9 mm
• Height: 78.7 mm
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V DC, 1.5 A
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DCS-4603  3 Megapixel Vigilance PoE Dome Camera
Attēli
DCS-4603/Ax
Вид слева
Вид сзади
Skatiet arī
