Ātrā meklēšana
Produkta iespējas:
4 Port USB 2.0 Pocket HUB
EOL EOS
Īpašības:
Standards
• USB specification version 2.0
• USB specification version 1.1*
• USB specification version 1.0
• OHCI (Open Host Controller Interface)
• EHCI (Enhanced Host Controller Interface)
Wiring topology
• Tiered Star
Connectivity
• Up to 127 devices by cascading multiple hubs
Compatible operating systems
• USB 2.0 Speed
  • Mac OS X 10.4.6 with USB 2.0 support
  • Microsoft Windows XP/Vista/7 with USB 2.0 support
• USB 1.x Speed
  • Mac OS 10.4.6 or above with USB 1.x support
  • Microsoft Windows XP/Vista/7 with USB 1.x support
Interfaces
• 1 upstream USB Type A (male) plug
• 4 downstream USB Type A (female) ports
Minimum system requirements
• For USB 1.1 Performance
  • Windows XP/Vista/7 with USB 1.1 support
  • MacoS X 10.4.6 with USB 1.1 support
• For USB 2.0 Performance
  • Windows XP/Vista/7 with USB 2.0 support
  • MacoS X 10.4.6 and above with USB 2.0 support
Diagnostic LED
• Power On (Blue)
Supplied current
• Bus power (Total power draw of all attached devices cannot exceed 500mA)
Power requirements
• No power adapter
Dimensions
• 76 x 46 x 18 mm
Weight
• 29.8 grams
Operating temperature
• 0В°C to 40В°C
Storage temperature
• -20В°C to 60В°C
Operating humidity
• 5% to 95% (non-condensing)
Storage humidity
• 0% to 95% (non-condensing)
Package contents
• D-Link 4-Port USB 2.0 Pocket Hub
Certifications
• FCC Class B
• CE
• C-Tick
* Using a USB 1.1 port will affect device performance.
All references to speed are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, actual product appearance may differ than that depicted on the packaging.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
