DCR-100EOL EOS
USB PC/SC Smart Card Reader Solution
Apraksts
Officially approve by Microsoft
The D-Link DCR-100 USB PC/SC Smart Card Reader complies with the PC/SC Version 1.0 standard and is officially approved by Microsoft. Moreover, this device can be fully used in conjunction with numerous other D-Link products to enhance user experience and improve the operations of your business or enterprise. This compact device operates quietly, making it ideal for use in virtually any room or office.
Plug and Play setup
The D-Link DCR-100 USB PC/SC Smart Card Reader includes a quick installation CD driver which allows the user an incredibly fast and easy configurations to set up their device and start using it right away.
Across-the-board certified
The D-Link DCR-100 USB PC/SC Smart Card Reader holds all of the following internationals certifications: UL, FCC, CE, EMV L1 (Version 2000).
Smart size and consumption
The D-Link DCR-100 USB PC/SC Smart Card Reader provides and enhances portability, as well as reduces power consumption, and has a longer product life without sacrificing operational performance or functionality through its compact size and USB connectivity.
Īpašības
Connecting interface
• USB 2.0
Host communication speed
• USB 2.0 (Full speed) 12 Mbps
IC card communication speed
• Up to 115200 bps
Environmental
• Operating temperature: 0° to 50°C
• Storage temperature: -35° to 70°C
Approval
• PC/SC 1.0/2.0
Compliant IC card standard
• CPU card: comply with ISO7816 - 1, 2, 3 T=1 and T=0 protocol
• Memory card: synchronous 2-line, 3-line and I2C interface
Driver support
• Win 2000/XP/Vista/Win7/CE, MAC OS, Linux
SDK (Software library)
• PC/SC compliant, CT-API
IC card
• 1 user card
Display
• Dual color (green/red) LED indicator
Sertifikāti
Informācija pasūtījumam
DCR-100 USB PC/SC Smart Card Reader Solution
