Ātrā meklēšana
Produkta iespējas:
7-port hub
Apraksts:
The D-Link DUB-H7 2.0 is a Hi-Speed USB 2.0 7-port hub that is backward compatible with USB 1.0 and 1.1. It provides an out of the box industry standard that allows connection of up to seven USB peripherals or devices to your USB ready PC or Mac. The D-Link DUB-H7 is targeted at PC and Mac users that are expanding the number of USB ports on their system.
Designed to provide quick and easy access, the D-Link DUB-H7 provides seven type "A" downstream ports for connecting USB peripherals, devices, or other USB hubs. A single type "B" upstream port connects the DUB-H7 to the host computer or another USB hub, enabling up to 127 devices to be connected by cascading multiple hubs. Configured directly by the operating system, the D-Link DUB-H7 operates seamlessly with both Microsoft Windows and Macintosh Operating Systems.
As a standard USB hub, the D-Link DUB-H7 buffers USB data from any attached peripheral in compliance with USB specifications to provide an invisible extension of the USB bus. Supporting both low speed (1.5Mbps and 12Mbps) and Hi-speed (480Mbps) devices, each port creates a bridge between the peripheral and host computer.
Diagnostic LEDs provide port status for each port and power status. The DUB-H7 includes a Quick Install Guide, a 6-foot Hi-Speed USB 2.0 certified 'A' to 'B' cable, and an AC power supply.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
