Ātrā meklēšana
Produkta iespējas:
PowerLine AV 4-Port Switch
Īpašības:
Minimum System Requirements
• Windows, Macintosh, or Linux-based operating system
• Ethernet adapter
Ports
• 4 x 10/100 Mbps Ethernet LAN (RJ-45)
Data Rates
• HomePlug AV: up to 200 Mbps*
LED Status Indicators
• Power
• Ethernet
• PowerLine
Interface
• Simple Connect Button
Fiziskie raksturlielumi
Power
• 100 V to 240 V, 50/60 Hz
Power Consumption
• < 5 W
Dimensions
• 137 x 110 x 32 mm
Weight
• 200 g
Operating Temperature
• 0°C to 40°C
Storage Temperature
• -10°C to 70°C
Operating Humidity
• 10% to 90%
Storage Humidity
• 5% to 95%
Certifications
• FCC
• UL
• CE
* Maximum throughput based on theoretical transmission PHY rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of traffic and network overhead, may lower actual data throughput rate. Interference from devices that emit electrical noise, such as vacuum cleaners and hair dryers, may adversely affect the performance of this product. This product may interfere with devices such as lighting systems that have a dimmer switch or a touch-sensitive on/off feature, short wave radios, or other PowerLine devices that do not follow the HomePlug AV standard.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
