Ātrā meklēšana
Produkta iespējas:
PowerLine AV Mini Adapter
Īpašības:
Powerline Interface
• Power plug (country-dependent)
Ethernet Interface
• 10/100 Fast Ethernet Port with RJ-45 Connector
Standards
• IEEE 802.3
• IEEE 802.3u
• Homeplug AV
• IEEE 1901
Security
• 128-bit AES data encryption
LEDs
• Power
• Ethernet
• PowerLine
Powerline Modulation Scheme
• OFDM symbol modulation
PowerLine Frequency Band
• 2 MHz to 30 MHz
Data Rate
• Powerline: Up to 200 Mbps (PHY rate)**
• Ethernet: 10/100 Mbps (autonegotiation)
Physical Parameters
Dimensions
• 65.7 x 47.7 x 25 mm
Weight
• 60 grams
Power
• Input: 100 to 240 VAC, 50/60 Hz
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• CE
• FCC
• CE/LVD
• UL
* Power outlets and electrical wiring must all be part of the same electrical system. Certain electrical conditions in your home, such as wiring condition and configuration, may affect the performance of this product. Additional D-Link PowerLine AV series products are required to add new devices to the network. A minimum of two D-Link PowerLine AV series products are required to create a network. Connecting this product to a power strip with a surge protector may adversely affect the performance of this product. For best results, plug the adapter directly into a wall outlet.
** Maximum throughput is based on theoretical transmission PHY rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of traffic and network overhead, may lower actual data
throughput rate. Interference from devices that emit electrical noise, such as vacuum cleaners and hair dryers, may adversely affect the performance of this product. This product may interfere with devices such as lighting
systems that have a dimmer switch or a touch-sensitive on/off feature, short wave radios, or other Powerline devices that do not follow the HomePlug AV standard.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
