ANT24-CB06NEOL
6 meter extension cable. N-male to N-female
Kur iegādāties
Apraksts
D-Link, the industry pioneer in wireless networking, introduces the D-Link ANT24-CB03N, ANT24-CB06N, and ANT24-CB09N Antenna RF Cables. These products are designed for outdoor or rooftop installations when distance between a wireless Access Point (AP) and an antenna is required. With these Radio Frequency (RF) cables and D-Link’s ANT24 line of outdoor antennas, an indoor wireless AP/Bridge can be used in an outdoor deployment*.
The D-Link ANT24 Antenna RF Cables are available in three lengths: 3m (9.84ft); 6m (19.68ft); and 9m (29.52ft). All of them can be inter-connected.  On one end of each cable is an “N-plug” and on the other end is an “N-jack” with high-quality N-type connectors.
The D-Link Antenna RF Cables are based on the HDF-400 specification to minimize the signal loss introduced to a wireless LAN. The frequency responses of the cables coincide with the 2.4GHz ISM band so that the cables are ideal for both IEEE 802.11b and IEEE 802.11g WLANs. With 50 ohms of impedance, the RF cables can be used with most D-Link WLAN products. This impedance match eliminates any Voltage Standing Wave (VSW) issues in an RF circuit, and any noticeable decrease in the amplitude of the RF signal.
D-Link includes a RF pigtail adapter in N-type *and SMA connectors with each of its ANT24 antennas. The D-Link Antenna Cables can be easily installed with surge protectors and D-Link Wireless APs. Using these reliable pre-cut RF cables with their pre-installed connectors ensures that the WLAN equipment operates optimally, providing the best performance possible. With a ANT24 Cable, deployment of an outdoor WLAN is now easier and more flexible than ever!
*Installers should abide by all FCC or local regulations and requirements before deploying outdoor antennas.
Īpašības
Operating Frequency Range
• 2.4~2.5 GHz
• 4.9~5.75 GHz
Nominal Characteristic Impedance
• 50Ω
Insertion Loss  @ 2.4-2.5 GHz
• 1.35~1.53dB
Insertion Loss  @ 4.9-5.75 GHz
• 2.22~2.41dB
VSWR
• 1.3:1 @2.4-2.5GHz
• 1.6:1 @4.9-5.75GHz
Cable Jacket
• Black Polyethylene
Connectors
• N Plug & N Jack
Minimum Bend Radius
• 12.7mm
Environment
• Outdoor/ Indoor
Operating Temperature Range
• -40 C to +85 C
Weatherproof
• Yes
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
ANT24-CB06N  6 meter extension cable. N-male to N-female
Attēli
ANT24-CB06N
Skatiet arī
