DWA-126EOL EOS
HIGH-POWER WIRELESS N 150 USB ADAPTER
Kur iegādāties
Apraksts
HIGH-SPEED Wireless NETWORKING
Connect to a high-speed wireless network with the D-Link High-Power Wireless N 150 USB Adapter and enjoy surfing the web, checking e-mail, and chatting with family and friends online. The DWA-126 uses Wireless N technology, which offers increased speed and range over the 802.11g/b standard1 giving you a faster, more reliable wireless connection.
CONNECT SECURELY TO YOUR WIRELESS NETWORK
To protect your data and privacy, the High-Power Wireless N 150 USB Adapter supports WEP, WPA, and WPA2 encryption for connecting to a secure wireless network, keeping your network traffic secure.
ENHANCED WIRELESS RANGE
The High-Power Wireless N 150 USB Adapter provides over 2x the wireless coverage of standard wireless N and reduces dead spots within the wireless range.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a secure wireless connection, so all you have to do is push a button to automatically create a secure wireless connection to your network, doing away with the need for configuring complicated settings.
Īpašības
SYSTEM REQUIREMENTS
Computer with:
• Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
• CD-ROM drive
• 20MB hard disk space
• Available USB port
STANDARDS
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
3dBi detachable Omni directional dipole antenna
SECURITY
• 64/128-bit WEP data encryption
• Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
• Wi-Fi Protected Setup (WPS)
• PBC/PIN
O.S. SUPPORT
Windows XP/Vista and Windows 7
Fiziskie raksturlielumi
OPERATING VOLTAGE
5VDC +/- 5%
EIRP
24dBm(MAX)
POWER CONSUMPTION
• TX: 392mA
• RX: 100mA
DIAGNOSTIC LEDs
Link/Activity
DIMENSIONS (L x W x H)
88.5 x 28 x 12 mm (3.5 x 1.1 x 0.5 inches)
OPERATING TEMPERATURE
0º to 40º C (32˚ to 104˚ F)
STORAGE TEMPERATURE
-20º to 65º C (-4˚ to 149˚ F)
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
• FCC Class B
• C-Tick
• Wi-Fi
Sertifikāti
Informācija pasūtījumam
DWA-126 HIGH-POWER WIRELESS N 150 USB ADAPTER
Attēli
DWA-126/A1
Skatiet arī
