Produkta iespējas:
Wireless N150 High-Gain USB Adapter EOL EOS |
Īpašības:
System Requirements
Computer with:
• Windows 7, Vista, or XP SP3
• CD-ROM drive
• 20MB hard disk space
• Available USB port
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• USB 2.0
Frequency band
• 2.4-2.4835GHz
Antenna
• The omni-directional dipole antenna 3dBi gain
Security
• 64/128-bit WEP data encryption
• Wi-Fi Protected Access (WPA and WPA2)
Wireless speed
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11 n: 150 Mbit/s
The output power of the transmitter
• IEEE 802.11b:
17 dBm (±2dB) at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
16~12 dBm at 6 Mbit/s
15 dBm at 24.36 Mbit/s
14 dBm at 54.48 Mbit/s
• IEEE 802.11n:
HT20
17 dBm at MCS0/1
16 dBm at MCS2/3
15 dBm at MCS4/5
14 dBm at MCS6/7
HT40
17dBm at MCS0/1
16 dBm at MCS2/3
15 dBm at MCS4/5
14 dBm at MCS6/7
Receiver sensitivity
• IEEE 802.11b:
17 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
-86 dBm at 6 Mbit/s
-85 dBm at 9 Mbits/s
-84 dBm at 12 Mbit/s
-84 dBm at 18 Mbit/s
-80 dBm at 24 Mbit/s
-77 dBm at 36 Mbit/s
-74 dBm at 48 Mbit/s
-68 dBm at 54 Mbit/s
• IEEE 802.11n:
HT20
-86 dBm at MCS0
-84 dBm at MCS1
-82 dBm at MCS2
-79 dBm at MCS3
-76 dBm at MCS4
-74 dBm at MCS5
-72 dBm at MCS6
-68 dBm at MCS7
HT40
-83 dBm at MCS0
-81 dBm at MCS1
-79 dBm at MCS2
-77 dBm at MCS3
-74 dBm at MCS4
-70 dBm at MCS5
-68 dBm at MCS6
-62 dBm at MCS7
Fiziskie raksturlielumi
Operating voltage
• 5VDC
Diagnostic LED
• Link/Activity
Power consumption
• In transmit mode: 230mA
• In receive mode: 140mA
Dimensions (L x W x H)
• 210 x 15 x 14mm
Weight
• 12.8g (unit)
Operating temperature
• 0° to 40°C
Storage temperature
• From -20° to 75°C
Operating humidity
• From 10% to 90%, non-condensing
Storage humidity
• From 5% to 95%, non-condensing
Certifications
• CE
• FCC Class B
• C-Tick
• Compatible with Windows 7
• IC
• Wi-Fi
• WPS
* Maximum wireless signal rate derived from IEEE standard specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors may adversely affect wireless signal range.
Skatiet arī
