Ātrā meklēšana
Produkta iespējas:
2.4GHz Omni-Directional Antenna for Indoor Use, 8dBi
EOL
Apraksts:
The D-Link ANT24-0802 is a high gain omni-directional antenna designed for 2.4GHz ISM band indoor use. This antenna provides high transmission/reception rates for wireless LAN devices operating on the 2.4GHz public industrial, scientific, and medical (ISM) frequency band. It can be used with 802.11b, 802.11g, and 802.11n wireless LAN devices such as access points and remote routers and provides point to multi-point coverage. This antenna can be used to replace the default antenna of your wireless device to expand its operation range. It can be connected to your wireless device through an extension cable provided with the antenna, or directly attached to your wireless device.
Accessories Included
The ANT24-0802 comes with a base that allows it to be installed in several different locations. The antenna is fitted into the base which can then be placed on a desktop or other flat surfaces, or attached to a wall with screws. The antenna can also be magnetically attached to a metallic surface with the built-in magnets on the underside of the base.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
