Ātrā meklēšana
Produkta iespējas:
Omni-Directional Antenna for Indoor Use, 8dBi
Īpašības:
Resistance
• 50 Ohms
Directionality
• Omni-directional
VSWR
• 2.0 (max)
The maximum gain
• 8dBi (lossless cable)
Allowable power
• 1W
Reflectivity
• -10dB (maximum)
Antenna type
• Collinear antenna
The diagram in the horizontal plane (vector H)
• 360°
Radiation pattern in the vertical plane (vector E)
• 24°
Fiziskie raksturlielumi
Jack
• RP-SMA
Operating temperature
• -10°C ~ +45°C
Storage temperature
• -20°C ~ +70°C
Operating humidity
• From 5% to 95% (non-condensing)
Humidity
The colour and material of the antenna
• Antenna: Black
• Antenna base: black
• Material: ABS, ABS+PC
Certifications
• RoHS
Weight
• 35g
Dimensions
• 325 x 13mm
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
