ANT24-0802CEOL
Omni-Directional Antenna for Indoor Use, 8dBi
Kur iegādāties
Apraksts
The D-Link ANT24-0802C is a high gain omni-directional antenna designed for 2.4GHz ISM band indoor use. This antenna provides high transmission/reception rates for wireless LAN devices operating on the 2.4GHz public industrial, scientific, and medical (ISM) frequency band. It can be used with 802.11b, 802.11g, and 802.11n wireless LAN devices such as access points and remote routers and provides point to multi-point coverage. This antenna can be used to replace the default antenna of your wireless device to expand its operation range.
Īpašības
Resistance
• 50 Ohms
Directionality
• Omni-directional
VSWR
• 2.0 (max)
The maximum gain
• 8dBi (lossless cable)
Allowable power
• 1W
Reflectivity
• -10dB (maximum)
Antenna type
• Collinear antenna
The diagram in the horizontal plane (vector H)
• 360°
Radiation pattern in the vertical plane (vector E)
• 24°
Fiziskie raksturlielumi
Jack
• RP-SMA
Operating temperature
• -10°C ~ +45°C
Storage temperature
• -20°C ~ +70°C
Operating humidity
• From 5% to 95% (non-condensing)
Humidity
The colour and material of the antenna
• Antenna: Black
• Antenna base: black
• Material: ABS, ABS+PC
Certifications
• RoHS
Weight
• 35g
Dimensions
• 325 x 13mm
Sertifikāti
Informācija pasūtījumam
ANT24-0802C Omni-Directional Antenna for Indoor Use, 8dBi
Attēli
ANT24-0802C
Skatiet arī
