ANT70-CB1RN
Antenna Extension Cable with RP-N Plug and N Plug Connectors, 1m
Apraksts
Antenna extension cords ANT70-CB1N and ANT70-CB1RN are used outdoors to connect to external access points D-Link. ANT70-CB1N is equipped with connectors N plug, and ANT70-CB1RN - Connectors RP-N plug and N plug. Cables have low data loss and can operate in two frequency bands - 2.4GHz and 5GHz. Both cables conform dust and moisture protection IP67, which means that they are dust and water tight and waterproof, and can be used in harsh outdoor conditions.
Īpašības
Frequency range
• 2.4~6GHz
VSWR
• 1.7:1 max. at 2.4GHz
• 2.7:1 max. at 5GHz
The insertion loss
• 0.8dB max. at 2.4GHz
• 2dB max. at 5.15~5.85GHz
Resistance
• 50 Ohms
Type of cable
• CFD-200
Cable Length
• 1m
Jack
• RP-N Plug, N Plug
Antenna structure
• Collinear
Sertifikāti
Informācija pasūtījumam
ANT70-CB1RN Antenna Extension Cable with RP-N Plug and N Plug Connectors, 1m
