DAP-1533EOL EOS
Wireless N450 MediaBridge®/Access Point
Apraksts
What it does
Whether you need high bandwidth for your Ethernet-ready devices in your entertainment system or you want to add wireless capability to your existing wired network, the Wireless N450 MediaBridge®/Access Point is perfect for you.
Wireless Bridge Mode
Four Gigabit ports let you connect wired devices such as media players, game consoles, and Network Attached Storage (NAS) to your existing wireless network, instantly giving them blazing wired speeds. Plus, by connecting a second Wireless N450 MediaBridge®/Access Point, you add a powerful wireless bridge with speeds of up to 450 Mbps.1
Access Point Mode
The Wireless N450 MediaBridge®/Access Point features selectable dual band – 2.4 GHz and 5 GHz, which lets you extend a network and connect devices. Connect the DAP-1533 to an existing wired network to make it wireless. Stream HD videos to the far corners of your home or play online games without any lag.
Īpašības
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.3
• IEEE 803.u
• IEEE 802.3ab
Computer with:
• Network Interface Card
• CD-ROM Drive
• Windows® 7 (2), Vista® (2), XP SP3 (2), or Mac OS® X (v10.4) (3)
• Internet Explorer® 7 or Mozilla® FireFox® 3.0 or higher
Physical interface
• 4 10/100/1000 Gigabit Ethernet Ports
• WPS Push Button (for Wi-Fi Protected Setup™)
• Mode Switch
- 2.4 GHz Access Point
- 5 GHz Access Point
- Bridge
• USB 2.0 Port
Operation modes
• 2.4 GHz Access Point
• 5 GHz Access Point
• Bridge
Wireless security
• Wi-Fi Protected Access (WPA/WPA2)
• WPS™
LEDs
• Power
• AP
• Bridge
Data Rate
• IEEE 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps
• IEEE 802.11b: 11, 5,5, 2 and 1 Mbps
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps
• IEEE 802.11n (2.4/5GHz): 6.5 to 450 Mbps
Transmitter Output Power
IEEE 802.11a
• 19 dBm at 6-18 Mbps
• 18 dBm at 24-36 Mbps
• 17 dBm at 48-54 Mbps
IEEE 802.11b
• 17 dBm at 1, 2, 5.5 and 11 Mbps
IEEE 802.11g
• 17 dBm at 6-36 Mbps
• 16 dBm at 48-54 Mbps
IEEE 802.11n (2.4GHz)
HT20
• 16 dBm at MCS0-MCS6, and MCS8-MCS13, and MCS16-MCS19
• 15 dBm at MCS7-MCS14, and MCS8-MCS13, and MCS19
• 14 dBm at MCS15 and MCS20-MCS22
• 13 dBm at MCS23
HT40
• 15 dBm at MCS0-MCS6 and MCS8-MCS13 and MCS16-MCS19
• 14 dBm at MCS7-MCS14 and MCS8-MCS13 and MCS19
• 13 dBm at MCS15 and MCS20-MCS22
• 12 dBm at MCS23
IEEE 802.11n (5GHz)
HT20
• 19 dBm at MCS0-MCS3, and MCS8-MCS11, and MCS16-MCS19
• 18 dBm at MCS4-MCS5 and MCS12-MCS13
• 17 dBm at MCS14
• 16 dBm at MCS6, and MCS15, and MCS20-MCS22
• 15 dBm at MCS7 and MCS23
HT40
• 17 dBm at MCS14
Receiver Sensitivity
IEEE 802.11a
• -82 dBm at 6 Mbps
• -81 dBm at 9 Mbps
• -79 dBm at 12 Mbps
• -77 dBm at 18 Mbps
• -74 dBm at 24 Mbps
• -70 dBm at 36 Mbps
• -66 dBm at 48 Mbps
• -65 dBm at 54 Mbps
IEEE 802.11b
• -87 dBm at 1 Mbps
• -87 dBm at 2 Mbps
• -85 dBm at 5.5 Mbps
• -82 dBm at 11 Mbps
IEEE 802.11g
• -82 dBm at 6 Mbps
• -81 dBm at 9 Mbps
HT20
• -82 dBm at MCS0/8/16
• -79 dBm at MCS1/9/17
• -77 dBm at MCS2/10/18
• -74 dBm at MCS3/11/19
• -70 dBm at MCS4/12/20
• -66 dBm at MCS5/13/21
• -65 dBm at MCS6/14/22
• -64 dBm at MCS7/15/23
HT40
• -79 dBm at MCS0/8/16
• -76 dBm at MCS1/9/17
• -74 dBm at MCS2/10/18
• -67 dBm at MCS4/12/20
• -63 dBm at MCS5/13/21
• -62 dBm at MCS6/14/22
• -61 dBm at MCS7/15/23
Device management
• Integrated Wireless Security Wizard and Wireless Protected Setup (WPS) support
• Windows Connect Now (WCN) support
• Web-based management using Internet Explorer 6 or higher, or other Java-enabled browser
• Online firmware update check
• Multi-language support
Sertifikāti
Informācija pasūtījumam
DAP-1533 Wireless N450 MediaBridge®/Access Point
