Ātrā meklēšana
Produkta iespējas:
Dual-Band 802.11n/ac Unified Wireless Access Point
Īpašības:
Wi-Fi Interface
• 802.11b/g/n 2.4 GHz Power Jack
• Factory Reset Button
• 1 RJ45 console port
• 802.11ac 5 GHz
• 1 power switch
LAN Interface
• 2 x auto-sensing 10/100/1000M Base-T
Antenna
• Internal omni-directional antennas
• 6.5 dBi for 5 GHz, 5 dBi or 2.4 GHz
Power Method
• Powered by PoE or 12 V/1 A
Wireless Frequency
• 802.11b/g/n: 2.4 GHz - 2.4835 GHz
• 802.11a/n/ac: 5.15 GHz - 5.35 GHz, 5.65 GHz - 5.85 GHz
Data Transfer Rate*
• 802.11n: 6.5 Mbp s- 450 Mbps
• 802.11b: 11, 5.5, 2, and 1 Mbps
• 802.11g: 54, 48, 36, 24, 12, 9, and 6 Mbps
• 802.11ac: 6.5 Mbps - 1300 Mbps
Operation Channel
• 2.4 GHz:
• 5 GHz
• 11 channels for United States
• 13 channels for Europe
• 13 channels for Japan
Web-based User Interface
• HTTP/HTTPS
Command Line
• RJ45 Serial Console
• Telnet/SSH
• SNMP
SSID Security
• 16 SSID
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA Personal/ Enterprise
• PSK and TKIP
Detection & Prevention
• Rogue and Valid AP Classification
Authentication
• MAC Address Filtering
Fiziskie raksturlielumi
Dimensions
• 198 x 171 x 40 mm
Weight
• 240 grams
Power Adapter
• Input: 100 to 240 V AC
• Output: 12 V DC, 1 A
Power over Ethernet
• 10/100/1000 Mbps PoE (802.3at) input
Enclosure
• Bottom cover – metal
• Top cover – plastic
• UL2043 certified
Temperature
• Operating: 0° to 40°C
• Non-operating: -20° to 65°C
Humidity
Certifications
• CE
• FCC
• IC
• cUL
• LVD
• UL2043 (for plenum-rated SKU only)
• C-Tick
• VCCI
• NCC
• Wi-Fi
• TELEC
* 300 Mbps is the maximum wireless signal rate as specified by IEEE 802.11n standard. Actual data throughput will vary. Network and other environmental factors, including volume of network traffic, building materials, and nearby radio interference may lower actual data throughput.
** This feature is available when Unified AP is used in conjunction with D-Link’s line of Unified Wireless Switches/controllers.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
