Ātrā meklēšana
Produkta iespējas:
802.11n/ac Unified Wireless Outdoor Access Point
Īpašības:
Interfaces
• 802.11a/g/n/ac 2x2 MIMO
• 2 x 10/100/1000 LAN ports
• 4 N-Type antenna connectors (2 x 2.4 GHz, 2 x 5 GHz)
Antenna
• 2 x 7 dBi gain for 5 GHz radio
• 2 x 5 dBi gain for 2.4 GHz radio
• 4 external omni-directional antennas included
Power Method
• PoE-powered through port LAN1 marked PoE-Input
Operating Frequency
• 2400 MHz to 2483.5 MHz ISM band
• 5.180 GHz to 5.240 GHz
• 5.280 GHz to 5.320 GHz
• 5.500 GHz to 5.700 GHz
• 5.745 GHz to 5.825 GHz
Operating Channels
• 1 to 13 channels for 2.4 GHz band (per country code)
• 36 to 165 channels for 5 GHz band (per country code)
Web-Based User Interface
• HTTP/HTTPS
SSID Security
• Up to 32 SSIDs, 16 per radio
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA/WPA2 Personal/ Enterprise
• AES
• TKIP
Detection & Prevention
• Rogue and Valid AP Classification
Authentication
• MAC Address Filtering
Dimensions
• 250 x 220 x 45 mm excluding mounting base
Weight
• 2053 g with antennas attached
• 1795 g without antennas attached
Power Consumption
• 16.5 W maximum
Power over Ethernet
• 802.3at compliant Power over Ethernet
Enclosure
• Metal and polycarbonate
• IP67-rated housing
• UL2043 certified
• GORE® Vent
Temperature
• Operating: -30 to 60 °C
• Storage: -30 to 70 °C
Humidity
Certifications
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS/TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• C-Tick
• NCC
• Wi-Fi
• LVD
• UL204
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
