DAP-3320/UPAEOL EOS
Wireless PoE Outdoor Access point
Apraksts
	The DAP-3320/UPA Wireless PoE Outdoor Access point is the ideal solution for expanding the coverage and signal strength of any wireless network. Built to withstand outdoor environments, the DAP-3320/UPA also excels in connecting separate networks that cannot be joined physically using traditional medium. Multiple operating modes, network management tools, and security features give network administrators a wide range of choices for deploying the device, allowing for the addition of wireless network-enabled devices.
	Increased Network Connectivity And Throughput
	Expand current wireless network capacity with 2.4 GHz 802.11n wireless connectivity. The built-in 2 dBi omni antenna* ensures that wireless signal will cover a wide area. Whether you want to connect additional wireless devices such as smartphones or laptops, or bringing connectivity to networks separated by short distances, the DAP-3320/UPA has it covered.
	Flexible Deployment Options
	The DAP-3320/UPA features four operation modes, allowing it to adapt to any situation. As a standard wireless Access Point (AP), the DAP-3320/UPA can connect to a wide range of devices that are 802.11n/g/b compliant. In Wireless Distribution System (WDS) mode, it can expand current wireless coverage, without the need for a wired backbone link. As a Wireless Client it can connect a non-wireless capable device to an existing AP. In addition, the DAP-3320/UPA is powered by PoE which allows for convenient installation, especially in places where a power supply is not reliable or power cables are not available or easily installed.
	Fine-Tuned Control Over Network Resources.
	The DAP-3320/UPA supports up to 8 SSIDs, allowing administrators to logically divide the access point into several virtual access points all within a single hardware platform. Rather than having separate networks with several access points, administrators can deploy one single AP to support more than one application, such as public Internet access and internal network control to increase flexibility and reduce costs. The DAP-3320/UPA supports 802.1Q VLAN tagging, operating with multiple SSIDs to segment traffic to enhance performance and security. The DAP-3320/UPA provides WLAN partitioning, a useful function for deployments such as wireless hot spots. With station-to-station partitioning enabled, security is enhanced, since wireless traffic is isolated from each other, and the possibility for data theft is reduced.
	Robust Security And Network Management Tools
	The DAP-3320/UPA supports 64/128-bit WEP data encryption and WPA/WPA2 security functions as well as MAC Address Filtering to control user access, and the Disable SSID Broadcast function to limit outsiders’ access to the internal network. Network administrators have multiple options for managing the DAP-3320/UPA, including web (HTTP), Secure Socket Layer (SSL), Secure Shell (SSH), and Telnet. For advanced network management, administrators can use the D-Link Central WiFiManager to configure and manage multiple access points from a single location. In addition, the D-Link Central WiFiManager provides network administrators with the means of conducting regular maintenance checks remotely, eliminating the need for sending out personnel to physically
	verify proper operation.
	The DAP-3320/UPA has a wireless scheduler feature, which turns off wireless functionality when it isn’t needed, saving power. With its high output power design, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-3320/UPA provides small to medium business and enterprise environments with a business-class solution for
	deploying a wireless network.
Īpašības
	Device Interfaces
	• 802.11n/g/b wireless
	• Reset Button
	• 10/100BaseT PoE Ethernet Port
	• Grounding Wire Connector
	LED
	• Power
	Antenna
	• 2 dBi Antenna
	Wireless Frequency
	• 2.4 GHz to 2.4835 GHz
	Standards
	• IEEE 802.11 b/g/n
	• IEEE 802.3u
	• IEEE 802.3
	• IEEE 802.3af
	Operation Mode
	• AP
	• WDS
	• WDS with AP
	• Wireless Client
	Network Management
	• Web Browser Interface
	• HTTP, Secure HTTP (HTTPS)
	• Telnet, Secure Shell (SSH)
	• D-Link Central Wi-Fi Manager
	• SNMP v1, v2c and v3
	• Traffic Control
	• AP Array Security
	Security
	• WPA2-Personal/Enterprise
	• WPA-Personal/Enterprise
	• WEP 64/128 bit Encryption
	• 802.1x
	• SSID Broadcast Disable
	• MAC Address Control
	• Network Access Protection
	SSID/VLAN
	• Support for up to 8 SSIDs/VLANs
	Enclosure
	• Waterproof IP55 Standard**
	Wireless speed***
	• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
	• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
	• IEEE 802.11n (2.4 GHz): 6.5 ~ 300 Mbit/s
	Transmitter Output Power*
	• IEEE 802.11b:
	  26.5 dBm at 1, 2, 5.5, 11 Mbit/s
	• IEEE 802.11g:
	  26.5 dBm at 6~36 Mbit/s
	  25 dBm at 48 Mbit/s
	  23 dBm at 54 Mbit/s
	• IEEE 802.11n:
	  2.4 GHZ/HT-20:
	  26 dBm at MCS0-MCS5, MCS8-MCS13
	  24 dBm at MCS6, MCS14
	  22 dBm at MCS7, MCS15
	  2.4 GHZ/HT-40:
	  21.5 dBm at MCS0-MCS6, MCS8-MCS14
	  21 dBm at MCS7, MCS15
	Receiver Sensitivity
	• IEEE 802.11b:
	  -95±2 dBm at 1 Mbit/s
	  -92±2 dBm at 2 Mbit/s
	  -91±2 dBm at 5.5 Mbit/s
	  -88±2 dBm at 11 Mbit/s
	• IEEE 802.11g:
	  -89±2 dBm at 6 Mbit/s
	  -88±2 dBm at 9 Mbit/s
	  -87±2 dBm at 12 Mbit/s
	  -86±2 dBm at 18 Mbit/s
	  -84±2 dBm at 24 Mbit/s
	  -81±2 dBm at 36 Mbit/s
	  -77±2 dBm at 48 Mbit/s
	  -75±2 dBm at 54 Mbit/s
	• IEEE 802.11n:
	  2.4 GHz/HT-20:
	  -89±2 dBm at MCS0/8
	  -87±2 dBm at MCS1/9
	  -86±2 dBm at MCS2/10
	  -82±2 dBm at MCS3/11
	  -80±2 dBm at MCS4/12
	  -75±2 dBm at MCS5/13
	  -73±2 dBm at MCS6/14
	  -72±2 dBm at MCS7/15
	  2.4 GHz/HT-40:
	  -87±2 dBm at MCS0/8
	  -85±2 dBm at MCS1/9
	  -84±2 dBm at MCS2/10
	  -80±2 dBm at MCS3/11
	  -78±2 dBm at MCS4/12
	  -73±2 dBm at MCS5/13
	  -71±2 dBm at MCS6/14
	  -70±2 dBm at MCS7/15
	Physical Parameters
	Dimensions
	• 105.43 x 228.6 x 35.86 mm
	Weight
	• 370.4 grams
	• 384.25 grams with mounting bracket
	Power Input
	• 48 V, 0.5 A or 802.3af PoE compliant
	Temperature
	• Operating: -20 to 60°C
	• Storage: -20 to 65°C
	Humidity
	• Storage: 5% to 95% non-condensing
	Surge Protection
	• 4 kV
	Certifications
	• CE
	• UL
	• Wi-Fi Certified
	• FCC
	• IC
	* Maximum power output varies in each country depending on local power regulations.
	** IP55 standard effective against low pressure jets of water from all directions without harmful effects. It is recommended to place this device under a roof or shelter when in severe weather environment.
	*** Maximum wireless signal rate derived from IEEE Standard 802.11g, and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Sertifikāti
Informācija pasūtījumam
