Ātrā meklēšana
Produkta iespējas:
Dual-Band 802.11n/ac Unified Wireless Access Point
Īpašības:
Interfaces
• 802.11b/g/n 2.4 GHz wireless
• 802.11ac 5 GHz wireless
• One 10/100/1000 LAN port
• RJ45 console port
• Factory reset button
• Power switch
• Power connector
Antenna
• Internal omnidirectional antennas
• 5 dBi for 5 GHz, 3.5 dBi for 2.4 GHz
Power Method
• Powered by PoE or 12 V / 2 A
Operating Channel
• 2.4 / 5 GHz
• 11 channels for United States
• 13 channels for Europe
• 13 channels for Japan
Web-based User Interface
• HTTP/HTTPS
Command Line
• RJ45 Serial Console
• Telnet/ SSH
• SNMP
SSID Security
• Up to 32 SSIDs, 16 per radio
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA Personal/ Enterprise
• AES and TKIP
Detection & Prevention
• Rogue and Valid AP Classification
Authentication
• MAC Address Filtering
Wireless Frequency Range
• 802.11b/g/n: 2.4 GHz to 2.4835 GHz
• 802.11a/n/ac: 5.15 GHz to 5.825 GHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36 and 54 Mbit/s
• IEEE 802.11n: 6.5 ~ 300 Mbit/s (MCS0 ~ MCS15)
• IEEE 802.11ac: 6.5 ~ 867 Mbit/s
Transmitter Output Power
• IEEE 802.11a:
  19±2 dBm at 6~36 Mbit/s
  15±2 dBm at 48 and 54 Mbit/s
• IEEE 802.11b:
  20±2 dBm at 1 and 2 Mbit/s
  17±2 dBm at 5.5 and 11 Mbit/s
• IEEE 802.11g:
  21±2 dBm at 6 and 9 Mbit/s
  20±2 dBm at 12 and 18 Mbit/s
  19±2 dBm at 24 Mbit/s
  18±2 dBm at 36 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  22±2 dBm at MCS0-MCS2, MCS8-MCS10
  20±2 dBm at MCS3-MCS5, MCS11-MCS13
  18±2 dBm at MCS6-MCS7, MCS14-MCS15
  2.4 GHz/HT-40:
  21±2 dBm at MCS0-MCS2, MCS8-MCS10
  19±2 dBm at MCS3-MCS5, MCS11-MCS13
  17±2 dBm at MCS6-MCS7, MCS14-MCS15
  5 GHz/HT-20:
  19±2 dBm at MCS0-MCS2, MCS8-MCS10
  17±2 dBm at MCS3-MCS5, MCS11-MCS13
  14±2 dBm at MCS6-MCS7, MCS14-MCS15
  5 GHz/HT-40:
• IEEE 802.11ac:
  VHT-20:
  19 dBm at MCS0-MCS3
  17 dBm at MCS4-MCS6
  15 dBm at MCS7-MCS8
  13 dBm at MCS9
  VHT-40:
  19 dBm at MCS0-MCS3
  17 dBm at MCS4-MCS6
  15 dBm at MCS7-MCS8
  12 dBm at MCS9
  VHT-80:
  19 dBm at MCS0-MCS3
  17 dBm at MCS4-MCS6
  15 dBm at MCS7-MCS8
  12 dBm at MCS9
Receiver Sensitivity
• IEEE 802.11a:
  -86±2 dBm at 6 and 9 Mbit/s
  -84±2 dBm at 12 Mbit/s
  -81±2 dBm at 18 Mbit/s
  -77±2 dBm at 24 Mbit/s
  -75±2 dBm at 36 Mbit/s
  -68±2 dBm at 48 Mbit/s
  -67±2 dBm at 54 Mbit/s
• IEEE 802.11b:
  -92±2 dBm at 1 Mbit/s
  -90±2 dBm at 2 Mbit/s
  -88±2 dBm at 5.5 Mbit/s
  -85±2 dBm at 11 Mbit/s
• IEEE 802.11g:
  -87±2 dBm at 6 и 9 Mbit/s
  -85±2 dBm at 12 Mbit/s
  -82±2 dBm at 18 Mbit/s
  -79±2 dBm at 24 Mbit/s
  -76±2 dBm at 36 Mbit/s
  -71±2 dBm at 48 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -85±2 dBm at MCS0/8
  -82±2 dBm at MCS1/9
  -80±2 dBm at MCS2/10
  -77±2 dBm at MCS3/11
  -74±2 dBm at MCS4/12
  -69±2 dBm at MCS5/13
  -68±2 dBm at MCS6/14
  -65±2 dBm at MCS7/15
  2.4 GHz/HT-40:
  -82±2 dBm at MCS0/8
  -79±2 dBm at MCS1/9
  -77±2 dBm at MCS2/10
  -74±2 dBm at MCS3/11
  -71±2 dBm at MCS4/12
  -66±2 dBm at MCS5/13
  -65±2 dBm at MCS6/14
  -62±2 dBm at MCS7/15
  5 GHz/HT-20:
  -82±2 dBm at MCS0/8
  -79±2 dBm at MCS1/9
  -70±2 dBm at MCS4/12
  -64±2 dBm at MCS7/15
  5 GHz/HT-40:
  -79±2 dBm at MCS0/8
  -76±2 dBm at MCS1/9
  -74±2 dBm at MCS2/10
  -71±2 dBm at MCS3/11
  -67±2 dBm at MCS4/12
  -64±2 dBm at MCS5/13
  -63±2 dBm at MCS6/14
• IEEE 802.11ac:
  VHT-20:
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
  -59 dBm at MCS8
  -57 dBm at MCS9
  VHT-40:
  -79 dBm at MCS0
  -76 dBm at MCS1
  -74 dBm at MCS2
  -71 dBm at MCS3
  -67 dBm at MCS4
  -63 dBm at MCS5
  -62 dBm at MCS6
  -61 dBm at MCS7
  -56 dBm at MCS8
  -54 dBm at MCS9
  VHT-80:
  -76 dBm at MCS0
  -73 dBm at MCS1
  -71 dBm at MCS2
  -68 dBm at MCS3
  -64 dBm at MCS4
  -60 dBm at MCS5
  -59 dBm at MCS6
  -58 dBm at MCS7
  -53 dBm at MCS8
  -51 dBm at MCS9
Physical Parameters
Dimensions
• 158.79 x 69.39 mm w/o bracket
Weight
• 500 grams
Power Adapter
• Input: 100 to 240 V AC
Max Power Consumption
• 16.6 W
Power over Ethernet
• 10/100/1000 Mbps PoE (802.3at) input
Enclosure
• Bottom cover – plastic
• Top cover – plastic
• UL2043 certified chassis
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 65°C
Humidity
• Operating: 10% to 90% (Non-condensing)
Certifications
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS/TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• Output: 12 V DC, 2 A
• LVD
• UL2043 (for plenum-rated SKU only)
• C-Tick
• BSMI
• NCC
• Wi-Fi
* This feature is available when Unified AP is used in conjunction with D-Link’s line of Unified Wireless Switches/controllers.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
