ANT24-1800EOL EOS
High Gain Directional Panel Antenna
Apraksts
The D-Link ANT24-1800 connects to the DWL-900AP+, DI-614+, DI-714P+, DWL-900AP, DI-714 and DI-713P to extend the range of coverage for the wireless network.
The D-Link ANT24-1800 antenna provides extended coverage for an existing 802.11b wireless local area network (WLAN). The D-Link ANT24-1800 comes with a conversion cable that allows connection directly to the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
This product includes the following items: Mounting Kit, Lightning Surge Protector, Conversion Cable.
The D-Link ANT24-1800 requires an access point or wireless broadband gateway with a reverse SMA connector.
NOTE: To obtain optimal results in extending wireless range with outdoor antenna installations, it is recommended that professional installer service is consulted for site survey and proper installation.
Īpašības
Connector
• N Jack
Frequency range
• 2.4 GHz ~ 2.5 GHz
Gain
• 18 dBi
VSWR
• 1.5 (max)
Polarization
• Linear, vertical
HPBW / horizontal
• 15°
HPBW / vertical
• 15°
Impedance
• 50 Ohms
Power handling
• 50 W
Physical parameters
Dimensions (L x W x H)
• 360 x 360 x 16 mm
Weight
• 1.6 kg
Survival wind speed
• 180 km/hr
Operating temperature
• -40 to +80 °C
Humidity
• 100% @ 25 °C
Sertifikāti
Informācija pasūtījumam
ANT24-1800 High Gain Directional Panel Antenna
