ANT24-0800EOL EOS
Outdoor 8 dBi Omni-Directional Antenna
Apraksts
The D-Link ANT24-0800 antenna connects to the 2.4 GHz wireless devices in order to extend the wireless network coverage. This model has 360 degree HPBW (horizontal) and 15 degree HPBW (vertical). The ANT24-0800 is supplied with a conversion cable that allows you to connect the antenna to the wireless devices with the reverse SMA connector. The rugged enclosure allows you to use the antenna in harsh environmental conditions.
Īpašības
Connector
• N Jack
Frequency range
• 2.4 GHz ~ 2.5 GHz
Gain
• 8 dBi
VSWR
• 2.0 (max)
Polarization
• Linear, vertical
HPBW / horizontal
• 360°
HPBW / vertical
• 15°
Impedance
• 50 Ohms
Power handling
• 50 W
Physical parameters
Dimensions
• Diameter: 19 mm
• Length: 520 mm
Weight
• 340 g
Operating temperature
• -40 to +80 °C
Humidity
• 90% @ 25 °C
Sertifikāti
Informācija pasūtījumam
ANT24-0800 Outdoor Omni-Directional Antenna, 8 dBi
