Ātrā meklēšana
Produkta iespējas:
Indoor 2.4GHz High Gain Directional Panel Antenna
Īpašības:
Electrical Properties
Frequency Range
• 2400-2500MHz
Peak Gain
• 12dBi
VSWR
• 1.5 : 1 Max
Polarization
• Linear, vertical
Horizontal Half Power Beam Width (HPBW/ H-PLANE)
• 80°
Vertical Half Power Beam Width (HPBW/ V-PLANE)
• 23°
Front to Back Ratio
• 15 dB
Downtilt
• 0°
Power Handling
• 20 W (cw)
Impedance
• 50 ohms
Connector
• SMA female (built-in)
Extension Cable
• 3 m with SMA and RP-SMA connectors
Mounting Type
• Window/ Wall
Physical & Environmental
Survival Wind Speed
• 180km/hr
Operating Temperature
• -10°C to +55°C
Operating Humidity
• 95% @ 55°C
Color
• White
Material
• ABS, UV resistant
Weight
• 190g
Dimensions
• 330 (L) x 93 (W) x 20.7 (H) mm
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
