Apraksts
D-Link, an industry leader in networking, introduces the ANT24-0700 Omni-Directional 7dBi Indoor Antenna designed to provide extended coverage for an existing 802.11b/g wireless network. The omni-directional design of the ANT24-0700 offers dramatically increased wireless signal coverage in all directions. With 360° of better signal reception, this high-gain antenna will also improve data throughput at further distances.
The D-Link ANT24-0700 Omni-Directional 7dBi Indoor Antenna connects to a variety of wireless routers and access points on the market today. Whether the wireless router or access point has a SMA or TNC connector, the ANT24-0700 comes with a RP-SMA to RP-TNC conversion adapter to accommodate either connector type.
For maximum flexibility in placement, the ANT24-0700 comes with a magnetic base unit* with 1.5m extension cable, and a mounting kit. The magnetic base unit has a incredible strong hold onto any metal surface.
Avoid the cost and complexity of adding additional access points or repeaters when you can easily use the ANT24-0700. Enjoy the benefits of wireless connectivity at greater distances throughout your home or small office.
* Warning: The base unit is magnetic. Keep magnetic base at least 6 inches away from electronic devices; computers, TV’s, video equipment, and tapes. Exposure to magnetic base may cause device or data on disks to become corrupted
