ANT24-0501EOL EOS
Indoor 2.4GHz Omni-Directional Antenna
Kur iegādāties
Apraksts
The D-Link ANT24-0501 is a high-Gain omni-directional antenna designed for2.4GHz ISM band indoor use. This antenna provides high transmission/reception rates for wireless LAN devices operating on the 2.4GHz public industrial, scientific and medical (ISM) frequency band. It can be used with 802.11b and 802.11g wireless LAN devices such as access points and remote routers. This antenna can be used to replace the default antenna of your wireless device to expand its operation range. It can be connected to your wireless device through an extension cable (provided with the antenna), or directly attached to your wireless device.
Īpašības
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
Attēli
ANT24-0501
Skatiet arī
