Ātrā meklēšana
Novecojis modelis - noņemts no ražošanas
Produkta iespējas:
WIRELESS G ACCESS POINT
Apraksts:
CONNECT HOME AND SOHO TO A WIRELESS NETWORK
Create a wireless network for your home and offce using the D-Link DAP-1160 is an 802.11g standard Wireless Access Point. Connect this Access Point to a broadband modem and wirelessly share your Internet connection. Enjoy surfng the web, checking e-mail, and chatting with family and friends online.
PROTECT WIRELESS NETWORK AND DATA
The DAP-1160 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. In addition, it also provides MAC address fltering and the Disable SSID Broadcast function to limit outsiders’ access to your home and offce network.
FLEXIBLY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1160 can be confgured to operate as (1) an Access Point to act as a central hub for wireless users, (2) an AP Client to connect to another Access Point, (3) a Bridge to joint two wireless workgroups together, (4) a Bridge with AP to act as wireless hub and a bridge at the same time, (5) a Repeater to extend the wireless coverage to cover all “dead” spots, (6) a WISP Client Router to let wireless Internet service subscribers share Internet connection with home/offce Ethernet-enabled computers without the need for an extra router, or (7) a WISP Repeater to let WISP subscribers share Internet connection with wireless computers without any extra router.
EASY TO INSTALL AND USE
With D-Link Setup Wizard, you can set up your wireless network in minutes. It confgures your DAP-1160’s operation mode, makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home and offce.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
