ANT70-1800EOL EOS
2.4GHz/5GHz High Gain Dual-Band Outdoor Directional Antenna
Apraksts
D-Link ANT70-1800 2.4GHz/5GHz High Gain Outdoor Dual-Band Directional Antenna is suitable for outdoor installation. It provides a Gain of 14dBi for 2.4GHz band and 18dBi for 5GHz band to give your wireless network an extended operating range. For best performance, users can use an antenna of the same Gain or higher, at the other end of the connection to take advantage of this antenna’s powerful signal transmission*.
Point-to-Point Application
The ANT70-1800 is ideal for operating in modes such as point-to-point WDS and others that require a high gain directional antenna. An example application of this antenna is to extend your local area network (LAN) by connecting LANs at two physically separated locations. Alternatively, Wireless Internet Service Provider (WISP) subscribers can also use this antenna to establish a strong connection between their host and to their ISP’s outdoor AP.
Weatherproof Design
The ANT70-1800 features a durable build and a waterproof design which provides complete protection from extreme weather. Furthermore, it is made of corrosion-resistant material, enabling it to withstand harsh outdoor conditions and wind speeds up to 216km/hr and is robust enough to remain outside indefi nitely. A surge arrestor is included to protect the antenna’s receiver from damaging voltages and other outdoor elements such as lightning.
Flexible Deployment
For ready installation, the ANT70-1800 antenna includes a pole mounting kit, which allows it to be placed on a pole for better wireless coverage. It also comes equipped with an indoor adapter cable fi tted with N-type and RP-SMA connectors for easy connection to a host.
*Transmission and reception distances can vary according to the transmission speeds. To get maximum signal coverage, make sure there is no obstruction in the signal path between the transmission and reception ends.
Īpašības
Frequency Range
• 2400 MHz to 2500 MHz
• 4900 MHz to 5875 MHz
Peak Gain
• 14dBi (2.4GHz frequency band)
• 18dBi (5GHz frequency band)
VSWR
• 2.0 : 1 maximum (2.4GHz frequency band)
• 2.0 : 1 maximum (5GHz frequency band)
Polarization
• Linear
• Vertical
Horizontal Half Power Beam Width (HPBW/ H-PLANE)
• 30º (2.4GHz frequency band)
• 15º (5GHz frequency band)
Vertical Half Power Beam Width (HPBW/ V-PLANE)
Front to Back Ratio
• 15dB
Downtilt
• 0°
Power Handling
• 10 W (cw)
Impedance
• 50 ohms
Connector
• N Jack (built-in)
Extension Cable
• 50 cm with RP-SMA and N-type connector
Mounting Type
• Pole
Surge Arrestor
• Included
Physical & Environmental
Survival Wind Speed
• 216 km/hr
Operating Temperature
• -40°C to +80°C
Operating Humidity
• 95% @ 55°C
Color
• Light gray
Material
• ABS, UV resistant
Weight
• 0.4 kg
Dimensions
• 200 (L) x 218 (W) x 50 (H) mm
Peak Gain
VSWR
Polarization
• Linear
• Vertical
Front to Back Ratio
• 15dB
Downtilt
• 0°
Power Handling
• 10 W (cw)
Impedance
• 50 ohms
Connector
• N Jack (built-in)
Extension Cable
Mounting Type
• Pole
Surge Arrestor
• Included
Survival Wind Speed
• 216 km/hr
• -40°C to +80°C
Operating Humidity
• 95% @ 55°C
Color
• Light gray
Material
• ABS, UV resistant
Weight
• 0.4 kg
Dimensions
Sertifikāti
Informācija pasūtījumam
ANT70-1800 2.4GHz/5GHz High Gain Dual-Band Outdoor Directional Antenna
