Standards
+ IEEE 802.11b/g WLAN
+ IEEE 802.3/802.3u Ethernet
+ IEEE 802.3x Flow Control
+ IEEE 802.3af PoE
Ethernet Interface
+ 10/100BASE-TX Ethernet port
Radio and Modulation Type
For 802.11b:
DSSS:
+ DBPSK @ 1Mbps
+ DQPSK @ 2Mbps
+ CCK @ 5.5 and 11Mbps
For 802.11g:
OFDM:
+ BPSK @ 6 and 9Mbps
+ QPSK @ 12 and 18Mbps
+ 16QAM @ 24 and 36Mbps
+ 64QAM @ 48 and 54Mbps
DSSS:
+ DBPSK @ 1Mbps
+ DQPSK @ 2Mbps
Operating Frequency
For 802.11b:
+ 2400 to 2497MHz
For 802.11g:
+ 2400 to 2483.5MHz
Channel Numbers
+ 11 Channels (FCC)
+ 13 Channels (ETSI)
Data Rates 1
+ 802.11g: 108,54, 48, 36, 24, 18, 12, 9 and 6Mbps
+ 802.11b: 11, 5.5, 2, and 1Mbps
Maximum Transmit Output Power 2
17dBm (typical)
Antennas
Embedded 9dBi patch antenna
RN-P N type connector for optional antenna5
Receiver Sensitivity
+ For 802.11b, at 8% PER:
11Mbps: –83dBm
2Mbps:–89dBm
+ For 802.11g, at 10% PER:
6Mbps:–87dBm
9Mbps:–86dBm
12Mbps:–85dBm
18Mbps:–83dBm
24Mbps:–80dBm
36Mbps:–76dBm
48Mbps:–71dBm
54Mbps:–66dBm
Security
+ 64/128/152-bit WEP data encryption
+ WPA-PSK, WPA2-PSK
+ WPA-EAP, WPA2-EAP
+ TKIP, AES support
+ MAC address filtering user access
+ WLAN partitioning
+ Multiple SSID for network segmentation
+ SSID broadcast disable function
+ 802.1Q VLAN Tagging
+ Rogue AP detection
+ Network Access Protection
Quality of Service
+ Wireless Multimedia (WMM)
Configurable Operation Modes
+ Access Point
+ WDS with AP
+ WDS
+ Wireless Client
Performance Enhancement
+ AP grouping for load balance
Device Management
+ Web Browser Interface:
- HTTP
- Secure HTTP (HTTPS)
+ AP Manager II
+ D-View
+ SNMP support:
- Private MIB
+ Command Line Interface:
- Telnet
- SSH
Diagnostic LEDs
+ Power
+ LAN
+ WLAN
Accessories Provided for Outdoor Installation
+ PoE base unit
+ Ethernet cable (4 meters long)
+ Set of grounding wires
+ Wall mount
+ Pole mount (option) 3
Fiziskie raksturlielumiOperating Voltage
48VDC +/- 10% for PoE
Power Consumption
+ 13.5 watts (max.) with PoE (with heater ON) 4
Dimensions
+ 190 (L) x 160 (W) x 55 (H) mm
Weight
+ 649g (Without mounting kit)
Operating Temperature
-20˚ to +60˚ C
Storage Temperature
-20˚ to +65˚ C
Operating Humidity
10% to 90% non-condensing, all-weather enclosure
Regulation Certification
+ FCC Class B
+ CE
+ IP 65
+ C-Tick
+ VCCI
+ TELEC
+ NCC
+ Wi-Fi
+ IC
+ CSA International
1 54Mbps maximum wireless signal rate derived from IEEE standard 802.11b and 802.11g specifcations. Actual data throughput will vary. 108Mbps when operating with other D-Link 108G wireless devices. Network conditions and environmental factors, including volume of network traffc c, building materials and construction, and network overhead lower actual data throughput rate. Environmental conditions will adversely affect wireless signal range.
2 Maximum power setting will vary according to individual country regulations.
3 This device can be mounted on a pole using an optional mounting kit (part number B15900-0033000).
4 Power consumption may exceed 802.3af PoE standard when heater is in operation; connect this device through the included PoE Base Unit.
5 Embedded patch antenna will be disabled when optional antenna is connected.
6 IP65 standard means the device is protected from dust and low pressure jets of water from all directions - limited ingress permitted. It is recommended to place this device under a roof.
