Ātrā meklēšana
Produkta iespējas:
VDSL2 MODEM ROUTER
EOL
Īpašības:
DEVICE INTERFACES
• 1 RJ-11 VDSL port (to VDSL line)
• 4 RJ-45 10/100BASE-TX Ethernet LAN ports with auto MDI/MDIX (to computers)
• Factory reset button
• Power ON/OFF switch
VDSL2 FEATURES
• VDSL Transmission Band Plan: ITU-T G.993.2
• VDSL Duplex Method: Frequency Division Duplexing, FDD for both DS/US
• VDSL Line-code Scheme: Multi-Carrier Modulation (MCM)
• VDSL Handshake Procedure: ITU-T G.994.1 compliant
• VDSL Physical-layer supports Packet Transport Mode (PTM)
• Supports Rate Adaptation
• Supports VDSL Line Status
• Performance: 80 Mbps downstream, 40 Mbps upstream
NETWORK PROTOCOLS & FEATURES
• NAT/NAPT (RFC 1631)
• RIP v1 (RFC 1058)
• RIP v2 (RFC 1389)
• Static Routing
• DNS
• TCP/UDP
• ARP/RARP (RFC 826)
• ICMP (RFC 791)
• DHCP Server/Client (RFC 213)1
• IP Multicast - IGMP Proxy/Snooping
• UPnP Compliant
• Virtual Server
• 802.1Q VLAN
• DMZ
• SNTP
FIREWALL/ACCESS SECURITY
• Built-in NAT firewall
• MAC Filtering
• Packet Filtering
• URL Filtering
• Denial of Service (DoS) prevention
• Challenge-Handshake Authentication Protocol (CHAP)
• DMZ
CONFIGURATION/MANAGEMENT
• Quick Installation Wizard
• Web-based GUI for remote/local management
• Firmware upgrade, configuration data upload/download via Web-based GUI
• Telnet for remote/local management
• Syslog monitoring
• SNMP v.1, v.2c support with built-in
MIB-I & MIB-II (RFC 1213)
• TR-069
QoS
• Traffic Prioritizaton/Classification
• Port-based priority
• 802.1p (0~7) priority  Diffserv-Codepoint IPQoS (TOS, 0~63)
• Source/Destination IP/Port-based priority
• Application port-based priority
• User-defined priority (TCP/UDP/ICMP)
SECURITY/BANDWIDTH MANAGEMENT
• IGMP Snooping v2/v3
• VLAN port mapping
DIAGNOSTIC LEDs
• Power
• LAN
• VDSL
• Internet
Fiziskie raksturlielumi
POWER INPUT
Through 12 V/1 A external power adapter
DIMENSIONS (L x W x H)
182 x 119 x 137 mm
OPERATING TEMPERATURE
0 to 40 ˚C (32 to 104 ˚F)
STORAGE TEMPERATURE
-20 to 70 ˚C (-4 to 158 ˚F)
OPERATING HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
CE
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
