DSL-2760U/BRU/DEOL EOS
802.11n ADSL2+ Modem Router
Apraksts
High-speed Internet
The DSL-2760U is a versatile, high-performance router for home and small office use. The DSL-2760U includes integrated ADSL2/2+ with download speeds of up to 24Mbps, firewall protection, Quality of Service (QoS), 802.11n wireless LAN, and 4 Ethernet switch ports. This router provides all of the functions that users need to establish a secure and high-speed remote link to the outside world.
Ultimate wireless connection
Maximize wireless performance and stay connected from virtually anywhere at home and in the office. The DSL-2760U provides wireless speeds many times faster than conventional 802.11g. Flexible user access security is provided via WPA/WPA2 and WEP data encryption. The DSL-2760U is also backward compatible with existing 802.11b and 802.11g wireless equipment, thus ensuring interoperability with a wide range of wireless devices.
Firewall protection and QoS
The DSL-2760U Modem Router provides firewall security measures such as Stateful Packet Inspection (SPI) and attack logging. SPI inspects the contents of incoming packets before they are allowed onto the network, while intelligent logging helps to protect against Denial of Service (DoS) attacks. Priority queues ensure Quality of Service (QoS) by organizing and delivering network traffic based on its importance. QoS is especially valuable on networks where users depend upon Voice over IP (VoIP) applications and streaming multimedia.
Share printers and network storage devices
Two USB 2.0 ports allow you to connect printers, external hard drives, or flash storage devices to your network. A built-in print server provides convenient remote printing functionality. Attached USB storage devices can be accessed over the network, allowing you to share files with ease.
Īpašības
Device interfaces
• ADSL: one RJ-11 port
• LAN: four RJ-45 10/100BASE-TX Fast Ethernet ports with auto-MDI/MDIX
• WLAN: 802.11n wireless interface
• Factory reset button
• Power on/off switch
Wireless LAN
• 802.11b/g
• 802.11n
• Wireless speed: up to 54Mbps (802.11g), 300Mbps (802.11n)*
• Frequency range: 2.4GHz to 2.484GHz
• Antennas: dual 2x2 built-in MIMO antennas
• 64/128 bits WEP data encryption
• WPA/WPA2 (Wi-Fi Protected Access) security
• Multiple SSID
• 802.11e Wireless QoS (WMM/WME)
• MAC-based access control
Wireless transmisiion power**
• 17dBm +/- 2dBm
ADSL standards
• ADSL standards: Multi-mode, ANSI T1.413 Issue 2, ITU G.992.1 (G.dmt)
Annex A, ITU G.992.2 (G.lite) Annex A, ITU G.994.1 (G.hs)
• ADSL2 standards: ITU G.992.3 (G.dmt.bis) Annex A/L/M, ITU G.992.4 (G.lite.bis) Annex A
• ADSL2+ standards: ITU G.992.5 Annex A/L/M
ADSL data rates
• G.dmt: 8Mbps downstream, 832Kbps upstream
• G.lite: 1.5Mbps downstream, 512Kbps upstream
• ADSL2: 12Mbps downstream, 1Mbps upstream
• ADSL2+: 24Mbps downstream, 1Mbps upstream
Virtual Private Network (VPN)
• Multiple PPTP/IPSec/L2TP pass-through
ATM & PPP protocols
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
• ATM Adaptation Layer Type 5 (AAL5)
• ATM QoS (Traffic Shaping)
• Bridged or routed Ethernet encapsulation
• VC/LLC-based multiplexing
• PPP over Ethernet (PPPoE)
• PPP over ATM (RFC 2364)
• ITU-T I.610 OAM F4/F5
Router features
• NAT
• DHCP server/client/relay
• Static Routing, RIP v.1, v.2
• Universal Plug and Play (UPnP) compliant
• Dynamic Domain Name System (DDNS)
• Virtual Server
• SNTP, DNS proxy and IGMP proxy
Firewall
• Built-in NAT firewall
• DoS attacks prevention
• Packet filtering (IP/ICMP/TCP/UDP)
• Intrusion Detection System (IDS)
• DMZ
Device configuration/management
• Web-based GUI for configuration, firmware upgrade
• Code lock to prevent improper firmware upgrade
• Telnet
• Syslog monitoring
• TR-069 Client
Quality of Service
• LAN to WAN traffic prioritization/classification
• 802.1p (0 to 7) traffic tagging
USB
• Printer server
• Storage device and hard drive for file sharing (Samba)
Sertifikāti
Informācija pasūtījumam
DSL-2760U/BRU/D 802.11n ADSL2+ Modem Router
