Ātrā meklēšana
Produkta iespējas:
ADSL Annex B/Ethernet Router with Built-in Switch
Apraksts:
Affordable solution for high-speed connectivity for your home or small office
DSL-2540U provides all the essentials for a safe, high-speed wireless network: ADSL/ADSL2/ADSL2+ standards, Fast Ethernet standard, built-in firewall, QoS engine, and numerous additional features.
Security
DSL-2540U is equipped with a built-in firewall. Advanced security features minimize threats of hackers, prevent intrusions to your network and block access to unwanted websites for users of your local network.
ADSL port and 4-port switch
ADSL router is equipped with a port for connecting to ADSL line and 4 Ethernet ports to connect workstations. Due to this feature DSL-2540U is a cost effective solution for wired networks without the need to install a separate switch. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
Configuration and management
You can configure and manage the DSL-2540U settings via the user-friendly web-based interface (the interface is available in several languages).
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
