DWR-710EOL EOS
Le Petit HSPA+ Router
Apraksts
	The D-Link DWR-710 Le Petit HSPA+ Router allows users to access worldwide mobile broadband networks. A slim, portable router with blazing fast speeds, the DWR-710 lets you do more with your 3G mobile connection than ever before. Once connected, users can get on the Internet, transfer files, stream media, and send and receive SMS messages. Simply insert your HSPA+ SIM card, plug in the DWR-710, and share your 3G Internet connection through a secure wireless network with other 802.11 b/g/n devices anytime, anywhere.
	Optimal Performance With HSPA+ Technology
	The Le Petit HSPA+ Router supports Evolved High Speed Uplink Packet Access (HSPA+) technology, which boosts maximum download speeds of up to 21 Mbps and upload speeds of up to 11.4 Mbps* to help reduce latency. HSPA+ is also backwards compatible with HSDPA, UMTS, EDGE, and GPRS technologies so you can stay connected wherever you are.
	Share Your Internet Access
	The DWR-710 also works as a Wi-Fi router, allowing you to connect it to a 3G network and wirelessly share your mobile Internet connection with any wireless-enabled PC or device. When you turn on Wi-Fi sharing mode, up to seven client devices such as smart phones, portable gaming devices, notebooks, and digital cameras will have fast access to your 3G Internet connection. When the Wi-Fi sharing mode is turned off, you can keep your PC connected to the 3G network while disabling its Wi-Fi radio to save battery power.
	Practical Portability
	The Le Petit HSPA+ Router is small enough to fit in your pocket – no batteries, cables, or additional hardware are required. The DWR-710 is easy to carry and its intuitive design guarantees portable convenience. No matter where you are and what devices you are carrying, you can stay connected with all your devices.
Īpašības
	GSM/GPRS/EDGE Band
	• 900/1800 MHz or 850/900/1800/1900 MHz
	• Power Class 4 (850/900 MHz)
	• Power Class 1 (1800/1900 MHz)
	UMTS/HSDPA/HSUPA/HSPA+* Band
	• 2100 MHz or 850/900/1900/2100 MHz
	• Power Class 3 (+24 dBm)
	System Requirements
	• Minimum: Windows XP/Vista/7/8, Mac OS X 10.5 or higher
	• 128 MB RAM or greater
	• 50 MB available disk space
	Data Throughput**
	• 3G Downlink: Up to 21 Mbps
	• 3G Uplink: Up to 11.4 Mbps
	Security
	• Built-in firewall
	• WEP/WPA/WPA2
	Standards
	• 802.11 b/g/n
	Web GUI
	• Internet Connection Setup Wizard
	• Connection Monitor
	• MAC Address Filter
	• Network Settings Manager
	• SMS Manager
	  - Compose/Send/Read/Delete SMS
	• Firmware Upgrades
Sertifikāti
Informācija pasūtījumam
