Ātrā meklēšana
Produkta iespējas:
Dual Port 10GBASE-T RJ-45 PCI Express Adapter
Īpašības:
Standards
• IEEE 802.1Q VLAN tagging
• IEEE 802.3x flow control
• IEEE 802.3an 10GBASE-T
• IEEE 802.3ab 1000BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ad Teaming
• PCI Express x8 2.0, 5 GT/s compliant
Power
• Maximum Power Consumption: 23.38 W
• Input Voltage: 3.3 V and 12 V
Data Transfer Rate
• 1 Gbps Full Duplex
• 10 Gbps Full Duplex
• Auto mode (support 100 Mbps)
Transmit Distance
• 10GBASE-T
  • 100M with Cat 6A or higher UTP
  • 50M with Cat 6 UTP
• 100/1000BASE-T
  • 100M with Cat 5 or higher UTP
Interface Slot
• PCI Express v2.0 x8/x16 slot
Supported Functions
• NIC Partitioning
• Other performance features
  • TCP, IP, UDP checksum
  • TCP segmentation
  • Adaptive interrupts
  • Receive Side Scaling (RSS)
• Manageability
  • Statistics for SNMP MIB II, Ethernet-like MIB, and Ethernet MIB
  • SMBus controller
  • IPMI support (IPMI pass thru mode)
• Advanced network features
  • Jumbo frames (up to 9 KB)
  • Virtual LANs
  • Smart Load Balancing Teaming
  • LiveLink™ (supported in both the 32-bit and 64-bit Windows operating systems)
• Logical Link Control (IEEE Std 802.2)
• Layer-2 Priority Encoding (IEEE Std 802.1p)
• High-speed on-chip RISC processor
• Up to 3 classes of service (CoS)
• Integrated 96 KB frame buffer memory
• Quality of Service (QoS)
• Support for multicast addresses via 256 bits hashing hardware function
• JTAG support
• PCI Power Management Interface (v1.1)
• 64-bit BAR support
• iSCSI Boot support
• Virtualization
  • Microsoft
  • VMware
Functionality
Driver Support
• Windows Server 2008(X86, X64)/2008 R2(X64)
• Windows Server 2012
• RHEL 6.4/6.5(X64), RHEL 5.9(X64)
• SLES 11.2/11.3(X64)
• Solaris 11/11.1
Diagnostic LED
• Speed/Link
• Activity
Physical
Dimensions
• 181 mm x 120.9 mm x 21.6 mm (7.13 x 4.76 x 0.85 inches)
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70 °C (-4 to 158 °F)
Humidity
• Storage: 10% to 90% non-condensing
Certifications
• CE
• FCC
• C-Tick
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
