DFE-520TXEOL EOS
10/100Mbps Ethernet PCI Card for PC
Apraksts
PCI Bus Master Performance Plugged into your PC's PCI expansion bus, this network card is automatically configured by the PC BIOS. Supporting 32-bit Bus Master operation, the card provides a guaranteed performance for your networked PC. Bus Master transfers data directly between the card and the PC host, bypassing your computer host CPU to alleviate its workload. This allows your computer to concentrate on the application at hand, instead of the network operation task.
10/100Mbps Connection
The card's single RJ-45 connector connects to either 10BASE-T Ethernet or 100BASE-TX Fast Ethernet. 10/100Mbps speeds are auto-negotiated, completely without your need to intervene.
802.3x Flow Control for Secure Transmission
In the fast 200Mbps full-duplex mode, the card's embedded flow control provides a means to protect your data against possible loss during transmission on the network. When connected to a LAN switch that supports flow control, the card receives signals from the switch regarding buffer overrun during peak usage periods. The card then delays transmission until the switch is ready again to accept new data.
Īpašības
Standards
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
- IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
- PCI local bus 2.2 specification
Topology
Star
Protocol
CSMA/CD
Network Data Transfer Rates
- 10BASE-T:
   10Mbps (half-duplex)
   20Mbps (full-duplex)
- 100BASE-TX:
   100Mbps (half-duplex)
   200Mbps (full-duplex)
Network Cables
- 10BASE-T:
   UTP Cat.3, 4, 5 (100 m max.)
   EIA/TIA-568 STP (100 m max.)
- 100BASE-TX:
   UTP Cat. 5 (100 m max.)
Diagnostic LED Report
- Link
- Activity
Power Consumption
0.4 watts max.
Dimensions
120 x 20 mm
Weight
106 grams
Operating Temperature
0 to 40 C
Storage Temperature
-10 to 70 C
Operating Humidity
10% to 90% RH
Storage Humidity
5% to 90% RH
Emission
- FCC Class B
- CE Class B
- C-Tick
O.S. Driver Support
Microsoft Windows 98 SE, 2000, ME, XP
Sertifikāti
Informācija pasūtījumam
DFE-520TX 10/100Mbps Ethernet PCI Card for PC
Attēli
DFE-520TX/A
View from the right
Pārlādēt
Skatiet arī
