Ātrā meklēšana
Produkta iespējas:
Wireless N VoIP VDSL2 modem router
Īpašības:
DEVICE INTERFACES
• 1 RJ-11 VDSL port (to phone line)
• 2 RJ-11 FXS ports (to analog phones)
• 1 RJ-11 PSTN port (lifeline to phone line)
• 4 RJ-45 10/100BASE-TX Ethernet LAN ports with auto MDI/MDIX (to computers)
• 1 USB 2.0 port
• 802.11n WLAN (AP wireless connection to computers)
• Factory reset button
• Power oN/oFF switch
• Wireless on/off switch
• WPS button
VDSL FEATURES
• VDSL Transmission Band Plan: ITU-T G.993.2
• VDSL Duplex Method: Frequency Division Duplexing, FDD for both DS/US
• VDSL Line-code Scheme: Multi-Carrier Modulation (MCM)
• 5-band operation meet ITU-T G.993.2, including U0, DS1, US1, DS2, US2, band from 25 kHz to 17 MHz
• VDSL Handshake Procedure: ITU-T G.994.1 compliant
• VDSL Physical-layer supports “Packet Transport Mode (PTM)”
• Supports Rate Adaptation
• Supports VDSL Line Status
• Performance: 100 Mbps downstream, 50 Mbps upstream
VoIP PROTOCOL SUPPORT
• SIP (RFC 3261)
TELEPHONE FUNCTION SUPPORT
• DTMF dial tone signal support
ĥ Caller ID support
AUDIO CODE
• G.711u-law/A-law
• G.723.1
• G.726
• G.729A/B
ECHO CANCELLATION
• G.168
FAX FUNCTION SUPPORT
• Transparent fax (G.711)
VoIP NAT TRAVERSAL
• SIP
WIRELESS LAN
• 802.11b/g standards
• 802.11n standard
• Wireless speed: up to 54 Mbps (802.11g), 300 Mbps (802.11n)
• Frequency range: 2.4 GHz to 2.484 GHz
• Antennas: dual 2x2 built-in MIMo antennas
• 64/128 bits WEP data encryption
• WPA/WPA2 (Wi-Fi Protected Access)security
• Multiple SSID
• 802.11e Wireless QoS (WMM/WME)
• MAC address-based access control
NETWORK PROTOCOLS & FEATURES
• NAT/NAPT (RFC 1631)
• RIP v1 (RFC 1058)
• RIP v2 (RFC 1389)
• Static Routing
• DNS
• TCP/UDP
• ARP/RARP (RFC 826)
• ICMP (RFC 791)
• DHCP Server/Client (RFC 2131)
• IP Multicast - IGMP Proxy/Snooping
• UPnP Compliant
• Virtual Server/Port Forwarding
• DMZ
• SNTP/NTP
• Printer sharing
FIREWALL/ACCESS SECURITY
• Built-in NAT firewall
• DoS attacks prevention
• Packet filtering based on port, source IP address, destination IP address, MAC address (ICMP/TCP/UDP)
VIRTUAL PRIVATE NETWORK (VPN)
• PPTP/L2TP/IPSec pass-through
QoS
• VLAN port mapping QoS for 4 LAN ports
• Packets classification (IP/MAC/Port and physical port)
• IP ToS
CONFIGURATION/MANAGEMENT
• Quick Installation Wizard
• Web-based GUI for remote/local management
• Firmware upgrade, configuration data upload/download via Web-based GUI
• Telnet server for remote/local management
• Syslog monitoring
• SNMP v.1, v.2c support with built-in MIB-I & MIB-II (RFC 1213)
• TR-069
BANDWIDTH MANAGEMENT
• IGMP Snooping
• VLAN port mapping
DIAGNOSTIC LEDS
• Power
• LAN 1 to 4
• WLAN
• USB
• VoIP 1 and 2
• PSTN
• VDSL
• Internet
• WPS
POWER INPUT
• Through 12 V/1.5 A external power adapter
OPERATING TEMPERATURE
• 0˚ to 40˚C
STORAGE TEMPERATURE
• -20˚ to 70˚C
OPERATING HUMIDITY
• 5% to 95% non-condensing
CERTIFICATIONS
• CE
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
