Ātrā meklēšana
Produkta iespējas:
VoIP Wireless Router
Apraksts:
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-G5402SP VoIP Wireless Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service. This VoIP Router connects you to up to two ordinary phone sets to let you make phone calls. Router connects you to up to two ordinary phone sets to let you make phone calls.  connects you to up to two ordinary phone sets to let you make phone calls.
SUPERIOR VOICE QUALITY
The DVG-G5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-G5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN in case when a power down occurs. This guarantees that your phone connection will always be available.
INTEGRATED WIRELESS 4-PORT ROUTER
The DVG-G5402SP provides a 802.11g standard wireless LAN and router function with built-in NAT/DHCP server to permit multiple computers to share an Internet broadband line. With four integrated Ethernet ports, four Ethernet-enabled computers and network devices can also connect to the DVG-G5402SP to log on to the Internet.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
