DEVICE INTERFACES
+ 2 RJ-11 FXS phone ports with polarity reversal detection and generation
+ 1 RJ-11 PSTN lifeline phone port
+ 1 RJ-45 10/100BASE-TX WAN port with auto-MDI/MDIX
+ 4 RJ-45 10/100BASE-TX LAN ports with auto-MDI/MDIX
GENERAL SIP FEATURES
+ Individual account per port or share account for all ports
+ Caller ID Delivery
+ Direct IP-to-IP Call without SIP Proxy
+ Digit Map and Phone Book
+ DNS SRV, SIP SRV
+ E.164 Numbering (with ENUM exception rule)
+ Group, Pick Up
+ Hot Line, Warm Line
+ Interactive Voice Response confguration (IVR)
+ Message Waiting Indication (SUBSCRIBE)
+ Visual Message Waiting Indication (SUBSCRIBE)
+ Music on hold
+ Outbound Proxy
+ SIP INFO
+ Three way conferencing (Ad Hoc mode, Media Server required)
+ Basic Call Features (Supplementary)
- ANONYMOUS CALL BLOCkING
- CALL BLOCk AND FILTER BY CALLER IP ADDRESS
- CALL FORWARDING - BUSY
- CALL FORWARDING - NO ANSWER
- CALL FORWARDING - UNCONDITIONAL
- CALL HISTORY (CALL STATUS)
- CALL HOLD
- CALL PICk UP
- CALL PARk AND RETRIEVE (PROXY SUPPORT)
- CALL TRANSFER (PROXY SUPPORT)
- CALL WAITING
- CALLING NAME AND TIME (FSk)
- DO NOT DISTURB
- CALLER ID BLOCkING
AUDIO FUNCTIONS
+ Adaptive Jitter Buffer
+ Adaptive Echo Canceller
+ Automatic voice/fax/data Detection and Switching
+ Auto Gain Control (AGC)
+ Codec: G711 μ/A-law, G729A/B/AB, G.723(6.3/5.3 kbps), G.726
+ Comfort Noise Generation (CNG)
+ DTMF Detection and Generation
+ In-band or Out of Band DTMF event
+ Packet Loss Concealment
+ Support voice/fax/modem (up to 33.6kbps) over IP
+ T.30 FAX bypass thought G.711
+ T.38 real time FAX up to 14.4 kbps
+ Voice Activity Detection (VAD)
+ Caller ID detection and generation: DTMF, FSk-BellCore, FSk-ETSI
CONFIGURATION/MANAGEMENT
+ Automatic Provisioning (exclusion from TR069/TR104 option)
+ WEB User Interface
+ TELNET User Interface
+ Confguration Backup and Restore through Web UI
+ Call History (Received Call/Disabled Call/Missed Call)
+ Flat Call Detail Record output (CDR)
+ Network Time Protocol time synchronization (Default by D-Link NTP)
+ Password Security (Web UI and TELNET)
+ Ping Test
+ Reset confguration to factory default
+ SNMP v2 (exclusion from TR069/TR104 option)
+ Static and Default routes
+ System status
+ TFTP/FTP/HTTP Client for frmware upgrade
+ TR069/TR104 Client support (optional)
WAN CONNECTION
+ Big Pond Client
+ DHCP Client
+ PPPoE Authentication by PAP/CHAP
+ PPTP Client
+ Static IP
QoS
+ DiffServ (DSCP) or ToS IP Precedence tagging (WAN)
+ LAN port rate limit
+ WAN port rate limit (in step of 64kbps)
+ WAN port priority queue: RTP frst
+ 802.1Q and 802.1P Tagging (1 VID for VoIP traffc, 1 VID for LAN traffc)
NAT TRAVERSAL
+ STUN Client
+ DDNS Client
+ SIP and RTP Port Range Designation
+ Static Route
SECURITY
+ Built-in Firewall
+ IP Filtering
+ Port Filtering
+ MAC Filtering
+ Virtual Server
+ DMZ
+ Denial of Service Protection (DoS)
+ MD5 Authentication for SIP
+ Two privilege login control: Administrator and User
+ VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP )
WIRELESS LAN
+ 802.11 b/g standard
+ Supports up to 64 client associations
+ Automatic RF channel selection
+ Wireless security: access control based on MAC addresses, 64/128-bit WEP data encryption, WPA/WPA support
Fiziskie raksturlielumiDIAGNOSTIC LEDS
+ Power
+ Provision/Alarm
+ Register
+ WAN Link/Activity
+ WLAN Link/Activity
+ LAN Link/Activity (4 Ports)
+ Phone(2 Ports)
+ Line
INPUT POWER
Through 100 to 240VAC, 50/60Hz, 1A external power adapter
OUTPUT POWER
12VDC, 1A
DIMENSIONS
193 x 118 x 31 mm
OPERATING TEMPERATURE
-10˚ to 40˚ C
STORAGE TEMPERATURE
-20˚ to 60˚ C (-4˚ to 140˚ F)
OPERATING HUMIDITY
10% to 90% RH
STORAGE HUMIDITY
5% to 95% RH
EMISSION (EMI) CERTIFICATIONS
+ FCC Class B
+ CE Class B
TELECOM CERTIFICATION
+ FCC PART 68
+ CE TBR21
