DGS-3208TGEOL EOS
6 100/1000Mbps fixed ports Gigabit Switch
Where to buy
Description
6 100/1000Mbps Ports
The switch provides 6 100/1000Mbps ports supporting 100BASE-TX and 1000BASE-T standards. Connection is through the twisted-pair copper wire cables using  RJ-45 connectors. These ports support NWay auto-negotiation for speed selection, full/half-duplex and flow control. At 2000Mbps full-duplex, these ports are suitable for connection to high-speed departmental servers.
2 GBIC-based Gigabit Ports
2 GBIC modularized Gigabit ports are provided supporting a number of network media, including multi-mode and single-mode fiber-optic cables. These ports come as open slots, all ready for connection; users select the desired connector modules and insert them in the slots.
Port Trunks for Aggregated Bandwidths
Multiple ports can be combined into a trunk, and multiple trunks can be configured for the switch. Each trunk forms a multilink load-sharing aggregated bandwidth between 2 switches or between a switch and a server. Users can also create backups between links to provide fail-safe connection to mission-critical servers or network centers.
VLANs for Performance and Security
The switch supports standard virtual LANs (VLANs) to extend the broadcast domain, segment network traffic and improve performance and manageability. This allows adds, moves and changes to be easily carried out. It also provides security by limiting broadcast domains, traffic in different segments and
subnets can be separated for maximum throughput and secure networking.
Flow Control Against Data Loss
The switch provides integrated IEEE 802.3x flow control in full-duplex. Flow control provides a means to protect users against possible data loss during transmission on the network. When connected to a node supporting flow control, the switch sends signals to the node regarding buffer overrun during peak usage periods. The sending node then delays transmission until the switch is ready again to accept new data.
SNMP Management, RMON Monitoring
The switch can be configured, managed and monitored in-band through an SNMP management program, or on the LAN from a Web browser. SNMP and other MIBs are built-in, and the Web-based management program is built into the switch. RMON monitoring and VLAN configuration through embedded RMON MIBs and standard VLAN MIBs. Telnet and out-of-band configuration are also supported.
General features
Standards
-IEEE 802.3u  100BASE-TX Fast Ethernet
-IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper twisted-pair)
-IEEE 802.3z 1000BASE-SX Gigabit Ethernet (fiber)
-ANSI/IEEE Std 802.3 NWay auto-negotiation
Protocol
CSMA/CD
Data Transfer Rates
-Fast Ethernet: 100Mbps (half duplex), 200Mbps (full duplex)
-Gigabit Ethernet: 1000Mbps (half duplex) 2000Mbps (full duplex)
Topology
Star
Network Cables
-100BASE-TX:
 2-pair or 4-pair UTP Cat. 5 (100m max.)
 EIA/TIA-568B 100-ohm STP (100m max.)
-1000BASE-T:
 4-pair UTP Cat. 5 or Cat. 5e (l00m max.)
-1000BASE-SX:
 62.5/125um multimode fiber-optics (275m max.)
 50/125um multimode fiber-optics (550m max.)
-1000BASE-LX:
 62.5/125um multimode fiber-optics (550m max.)
 50/125um multimode fiber-optics (550m max.) 10um multimode fiber-optics (5km max.)
-Long Haul:
 Single-mode fiber-optics (70km max.)
Full/half Duplex
-Full/half duplex for 100/1000Mbps ports
-Full duplex only for GBIC Gigabit ports
Head of Line Blocking Enable/Disable
For 100/1000Mbps ports only
Flow Control
-IEEE 802.3x in full duplex
-Back pressure in half duplex
Auto-negotiation
(for 100/1000Mbps ports only)
-100/1000Mbpsspeed
-Full/half duplex
-Flow control
Performance
Transmission Method
Store-and-forward
Filtering Address Table
12K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates
-FastEthernet:148,810 pps per port
-Gigabit Ethernet: 1,488,100 pps per port
RAM Buffer
2MB per port
LED Report
-100Mbps speed (ports 1 to 6)
-1000Mbps speed (ports 1 to 8)
-Link/Activity (every port)
-Full duplex (every port)
-Console port status
-Power status
Management
Standards
-Management: SNMP, web-based
-Spanning Tree Protocol: IEEE 802.1D
-VLAN IEEE 802.1Q
-RMON group 1, 2, 3, 9 statistics, history, alarms, events
-Telnet
MIBs
-SNMP MIBs
-MIB-II RFC 1213
-Bridge MIBs RFC 1493
-RMON MIBs RFC 1757
-VLAN MIBs
-IGMP
-D-Link Enterprise MIBs
-IEEE 802.1D MIB
Management Functions
-Port Security
-Bootp, DHCP client
-Log file upload
-Config file upload/download
Console Port
-DB-9 RS-232 DCE x 1
-SLIP support
AC Input
100 -240 VAC, 50/60 Hz Internal universal power supply
Power Consumption
50 watts (max.)
Ventilation
40 x 40 mm DC fan x 3
Operating Temperature
0°- 50° C (32°- 104° F)
Storage Temperature
-25°-55° C (-113°- 131° F)
Relative Humidity
5% - 95% non-condensing
Dimensions
441 x 367 x 44mm (1 U)
(17.4 x 14.45 x 1.73 inches)
19-inch rack-mount width
Weights
5 kg (11 lb.)
Emission (EMI)
-FCC Class A
-CE Class A
Safety
-UL
-CSA
-TUV/GS
Certificates
Order info
Gigabit Switch
DGS-3208TG
6 100/1000Mbps fixed ports (RJ-45 connectors two expansion slots for optional module), (2 1000Mbps ports (GBIC-based) with SNMP, RMON agents.
Optional Module
DGS-701
1000BASE-SX GBIC FTR-8519-3A (Finisar)
Wavelength: 850nm
Fiber Type: 50um/125um 500 MHz-km multimode fiber Distance: 550m
Pictures
Downloads
Support Resources
