DES-132FEOL EOS
2-port 100Base-FX, Multimode Smart Switch Module
Description
The DES-132F is a 2-port fiber ethernet module that is fully complaint with IEEE standards. It contains 2 100Base-FX Gigabit ports (SC connectors) and supports 2 km multi-mode fiber. It is compatible with DES-3226S and DES-3226SR switches.
General features
- IEEE 802.3u 100BASE-FX standard
- 1/2 100Mbps fiber port(s) (SC connectors)
- Full duplex support
- IEEE 802.3x Flow Control
- Cables: 50, 62.5/125-micron multi-mode fiber (2 km max.)
- LED report (per port): Link/Act
Certificates
Order info
DES-132F 2 100BASE-FX multi-mode fiber ports (SC connectors)
