DHS-3226EOL EOS
Description
The D-Link’s managed DHS-3226 Switch are the Layer 2 switch that provides 24 10/100Mbps Fast Ethernet ports and optional module. 24 10/100Mbps Fast Ethernet ports allow you to connect to another LAN switches and Hubs, or directly connect to the power users. Optional module provides 2-ports 100Mbps or 1000Mbps connection to servers or Enterprise core switches.
General features
24 fixed 10/100BASE-TX Port on front panel
- IEEE 802.3 10BASE-T and IEEE 802.3u 100BASE-TX compliance
- Support auto-negotiation 10M/100M speed function
- Support auto-negotiation Full/Half Duplex operations
- Support auto-polarity detection and correcting
- All port support Auto MDI/MDI-X
Performance
64 Byte system packet forwarding rate
6.6 Mpps
Wire speed on all ports and port options
Full-wire speed (full-duplex) operation on all ports including Gigabit ports.
Forwarding Mode
Store and Forward
Priority Queues
4 Priority Queues per port
MAC Address table
Supports 8K MAC address
Packet Buffer memory
Supports 16M Bytes buffer memory per device
Software Features
CoS
- Classification based on 802.1p priority
- Classification based on MAC SA/DA
- Number of priority queues supported
- Classification based on T.O.S priority
- Classification based on IP destination address
- Classification based on TCP/UDP destination port number
- DSCP
Spanning Tree Support
- 802.1D Spanning tree compatible
- 802.1w Rapid Spanning Tree support
VLAN
- 802.1Q support
- Port-based VLAN
- GARP/GVRP
- Number of VLANs supported per device
- Asymmetric VLAN (L2 mode only)
IP Multicast
- IGMP Snooping
- IGMP Snooping support fast leave
Configuration
- Telnet Server
- TFTP Client
- BootP Client
- DHCP Client
Management
- Password enabled
- Web-based support
- SNMP v1 support
- SNMP v2c support
- SNMP v3 support
- TFTP upgrade
- Command Line Interface (CLI)
- Traffic Segmentation
- Bandwidth control
- Support SYSLOG
- Support DiffServ setting
- Support Port Security
- Support Cisco-Like Port Security function
- Web GUI Traffic Monitoring
- Web MAC address browsing
- SNMP Trap on MAC Notification
- SNTP support
MIB Support
- RFC1213 MIB II
- RFC1493 Bridge
- RFC1757 RMON
- RFC 1643 Ether-like MIB
- Private MIB
- 802.1p RFC2674
- IF MIB
- IGMP MIB
RMON
4 Groups of RMON (Statistics, History, Alarms, Events)
Port configuration & Monitoring
- Auto-Negotiation Support
- Port Mirroring
- Support Broadcast storm control
Port Trunking
Ether Channel Interoperable/ 802.3ad static mode
802.3ad
- 802.3ad compatible Link Aggregation static mode
- 802.3ad LACP dynamic mode
Security
- Support 802.1X Port-based Access Control
- Support 802.1X MAC-based Access Control
Access Control List support (ACL)
- Based on MAC address
- Based on VLAN
- Based on IP address
- Based on Protocol Type
- Based on TCP/UDP port number
- Based on 802.1p
- Based on DSCP
- TCP SYN establish ACL
Certificates
Order info
DHS-3226 24-port 10/100Mbps L2 Switch with optional expansion slot
Optional modules
DES-132FL 2-port 100BASE-FX Ethernet Module (Single mode)
DES-132F 2-port 100BASE-FX Ethernet Module (Multimode)
DES-132T 2-port 1000BASE-T Gigabit Ethernet Module
DES-322T 2-port 1000BASE-T Gigabit Ethernet Module
DES-131F 1-port 100BASE-FX Ethernet Module (Multimode)
DES-131FL 1-port 100BASE-FX Ethernet Module (Single mode)
DES-132 2-port 10/100BASE-TX module
DES-132G 2-port 1000BASE-SX Gigabit Ethernet Module
DES-132GL 2-port 1000BASE-LX Gigabit Ethernet Module
DES-132GB 2-port GBIC-based Gigabit Ethernet Module
DEM-320S 2-port 1000BASE-SX Gigabit Ethernet Module
DEM-320L 2-port 1000BASE-LX Gigabit Ethernet Module
