Quick find
Product features:
Web Smart 24-Port 10/100/1000BASE-T PoE + 4 combo SFP Switch
General features:
General
Port Standards & Functions
+ IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
+ IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
+ IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted- pair copper)
+ IEEE 802.3z Gigabit Ethernet (fber) ANSI/IEEE 802.3
+ NWay Auto-Negotiation
+ IEEE 802.3x Flow Control
+ 802.3af Power over Ethernet (for DGS-1224TP only)
Number of Ports
24 10/100/1000BASE-T PoE ports, 4 combo SFP slots
* Use of SFP will disable their corresponding 10/100/1000BASE-T connections
SFP Modules
+ Optional SFP Transceivers:
- DEM-310GT 1000BASE-LX, Single-mode, 10km
- DEM-311GT 1000BASE-SX, Multi-mode,500m
- DEM-312GT2 1000BASE-SX, Multi-mode, 2km
- DEM-314GT 1000BASE-LX, Single-mode, 50km
- DEM-315GT 1000BASE-LX, Single-mode, 80km
+ Optional WDM Transceivers:
- DEM-330T (1000BASE-LX, wavelength Tx: 1550nm, Rx: 1310nm, Single-mode, 10km)
- DEM-330R (1000BASE-LX, wavelength Tx: 1310nm, Rx: 1550nm, Single-mode, 10km)
- DEM-331T (1000BASE-LX, wavelength Tx: 1550nm, Rx: 1310nm, Single-mode, 40km)
- DEM-331R (1000BASE-LX, wavelength Tx: 1310nm, Rx: 1550nm, Single-mode, 40km)
Data Transfer Rates Ethernet:
+ 10Mbps (half duplex)
+ 20Mbps (full duplex)
Fast Ethernet:
+ 100Mbps (half duplex)
+ 200Mbps (full duplex)
Gigabit Ethernet:
2000Mbps (full duplex)
Topology
Star
Network Cables
+ UTP Cat. 5, Cat. 5e (100 meters max.)
+ EIA/TIA-568 100-ohm STP (100 meters max.)
Full/half Duplex
+ Full/half duplex for 10/100Mbps speeds
+ Full duplex for Gigabit speeds
Media Interface Exchange
Auto MDI/MDIX adjustment for all twisted-pair ports
LED Indicators
+ Per device: Power/PWR Max/CPU/Fan Error
+ Port LED Mode Indicator: Link/Act Mode/PoE Mode
+ Per 10/100/1000BASE-T port: Link/Act, 100/1000Mbps
+ Per SFP slot: Link/Act, 1000Mbps
Software
L2 Features
+ IGMP v1/2 Snooping: supports 64 multicast groups
+ 802.1D Spanning Tree
+ Static Port trunk (Link Aggregation): up to 6 groups per device, up to 8 ports per group
VLAN
+ 802.1Q VLAN (VLAN Tagging)
+ Up to 256 static VLAN groups
+ Management VLAN
+ Asymmetric VLAN
QoS (Quality of Service)
+ 802.1p Priority Queues
+ Up to 4 queues per port
+ DSCP-based QoS
+ Supports WRR or Strict Mode in Queue Handling
Security
+ 802.1X Port-based Access Control
+ Broadcast Storm Control: threshold of 8K, 16K, 32K, 64K, 128K, 256k, 512K, 1024K, 2048K, 4096K bytes per second
+ D-Link Safeguard Engine to protect CPU from broadcast / multicast / unicast fooding
+ Trusted Host
+ Cable Diagnostics function
Management Web-based GUI
+ SNMP v1 support
+ DHCP Client
+ Trap setting for destination IP, system events, fber port events, twisted-pair port events
+ Port Access Control
+ Web-based: Confguration backup/restoration
+ Web-based: Firmware backup/upload
+ Firmware upgrade using SmartConsole Utility
+ System Reboot using web-based interface
+ SmartConsole Utility
MIB
+ RFC 1213 MIB-II
+ D-Link Enterprise Private MIB
Performance
Switch Capacity
48Gbps
Transmission Method
Store-and-forward
MAC Address Table
8K entries per device
MAC Address Update
+ Up to 256 static MAC entries
+ Enable/disable auto-learning of MAC addresses
Maximum 64 bytes packet forwarding rate
35.7Mpps
RAM Buffer
512Kbytes per device
Jumbo Frame
10,240bytes
Physical & Enviromental
AC Input
100 to 240 VAC 50/60Hz internal universal power supply
Power Consumption
250.3W
PoE Budget
180watts
DC Fans
2pcs
Heat Dissipation
854.02BTU/hr
Acoustic Value
47 dB(A)
Operating Temperature
0˚ to 40˚ C
Storage Temperature
-10˚ to 70˚ C
Operating Humidity
10% to 90% non-condensing
Storage Humidity
5% to 90% non-condensing
Dimensions
+ 440 x 210 x 44 (mm)
+ 19-inch standard rack mounting width, 1U height
Weight
3.6 kg
EMI
+ FCC Class A
+ CE Class A
+ VCCI Class A
MTBF
173,467 hours
Safety
cUL, LVD
Products | Support  | News  | About
