Quick find
Product features:
24 ports compact 11” EasySmart switch
General features:
Port Standards & Functions
Size
11-inch Desktop Size, 1U Height 11-inch Desktop Size, 1U Height
Interface
24 10/100BASE-TX 24 10/100BASE-TX
Port Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• Supports Half/Full-Duplex operations
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
Performance
• Switching Capacity: 4.8 Gbps
• Max. Forwarding Rate: 3.57 Mpps
• MAC Address Table-Size: 8K Entries
• Packet Buffer: 1.75 Mbits
• Flash Memory: 1 MB
LEDs
• Power (Per Device)
• Link/Activity/Speed (Per Port)
Software Features
L2 Features
• MAC Address Table: 8k
• IGMP Snooping
• Static Trunk:
+ Max 2 groups per device and 2-4 ports per group
• Flow Control
• Loopback Detection (LBD)
• Port Mirroring:
+ Supports One-to-One or Many-to-One
+ Supports TX, RX and both
• Statistics -supports 4 groups:
+ Transmit packet & collision
+ Receive packet & Transmit packet
+ Receive packet & Drop packet
+ Receive packet & CRC packet
VLAN
• 802.1Q Tagged VLAN
• VLAN Group:
+ Supports 32 static VLAN groups
+ Configures VID from 1-4094
• Port-based VLAN
Quality of Service (QoS)
• Bandwidth Control:
+ Port-based (Ingress/Egress)
+ Granularity is predefined as: 512 kbps/1024 kbps/2048 kbps/4096 kbps/8192 kbps/16384 kbps/32768 kbps
• 4 queues per port
• 802.1p
• Queue Handling:
+ Strict Priority
+ Weighted Round Robin (WRR)
Security
• Static MAC (Max 128 Static MAC entries)
• Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Web-based GUI (Supports IPv4)
• SmartConsole Utility
• Password Access Control
• Port Setting: Set Speed, Duplex mode, flow control
• Configuration File Backup/Restore via HTTP
• Firmware File Upgrade via HTTP
MTBF (Hours)
562,066 hours
Acoustic
0 dB
Heat Dissipation
26.20 BTU per hour
Power Input
100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Max Power Consumption
7.68 Watts
Dimensions
280 (W) x 125 (D) x 44 (H) mm
Ventilation DC Fan
Fanless
Operating Temperature
0 to 40 C
Storage Temperature
-10 to 70 C
Operating Humidity
10% to 95% non-condensing
EMI
FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Safety
UL/cUL, LVD
Products | Support  | News  | About |
