DPS-600EOL EOS
Redundant Power Supply, 500 watts
Where to buy
Description
DPS-600 redundant power supply (RPS) is designed to conform to the wattage requirements of D-Link’s Ethernet and Gigabit switches. This is external RPS enclosed in solid metal cases with sockets to AC or DC power sources on one end, and connectors to the switch’s internal power supply on the other end. DPS-600 provides a low-cost, simple solution to the problem of an inadvertent failure of the internal power-supply of the Ethernet switch, which can result in the shutdown of that switching device, the devices attached to its ports, or an entire network. Supporting full output power for the switch, this redundant power supply can maximize the power availability of the switching device.
Redundant Power Backup
DPS-600 is equipped with an integrated detection circuit that continuously monitors the switching device’s internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply.
Easy and Flexible Deployment
Deployment of a DPS-600 does not necessitate any change in configuration of the LAN switch. DPS-600 is equipped with a universal internal power supply, and can be connected to any AC main power source from 85VAC to 264VAC, 47Hz to 63Hz through a standard AC power cable.
DPS-600 Redundant Power Supply
DPS-600 is 19-inch standard-size rack mount power supply designed to improve flexibility in supporting PoE (Power over Ethernet) equipment.
General features
Output power
500 watts
Input voltage range
90 to 264VAC
Input frequency
47 to 63 Hz
Max input current
10A @ 115VAC
5A @ 230VAC
Max inrush current
30A @ 115VAC
60A @ 230VAC
Efficiency
80%
Operating temperature
0 to 50°C
Storage temperature
-40 to 85°C
Operating humidity
10% to 90% non-condensing
MTBF
598,664 hours
Dimensions
441 x 139 x 44.5mm
Weight
4.46kg
Certificates
Order info
DPS-600  Redundant Power Supply, 500 watts
Pictures
DPS-600
Front view
Back view
Downloads
Support Resources
