DES-1005PEOL EOS
5-port 10/100 switch with one PoE port
Description
	FAST INTERNET CONNECTION AT HOME
	The D-Link DES-1005P 5-port 10/100 Switch with One PoE Port allows you to easily connect a Power over Ethernet (PoE) device such as a wireless access point (AP), IP camera, or IP phone. The switch also gives you the opportunity to add additional Ethernet devices such as computers, printers, and Network Attached Storage (NAS) onto your network. This compact PoE switch operates quietly, making it ideal for use in virtually any room or office.
	POWER OVER ETHERNET (PoE)
	The first port of the DES-1005P supports the IEEE 802.3af PoE standard. The port supplies a total PoE budget of 15.4 watts, allowing users to attach an IEEE 802.3af-compliant device to the DES-1005P that requires no additional power. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables.
	AUTO MDI/MDIX CROSSOVER
	All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
	CONSERVES ENERGY
	The DES-1005P 5-Port 10/100 Switch makes use of D-Link green™ eco-friendly technology, providing energy savings, reduced power consumption, and a longer product life without sacrificing operational performance or functionality. This switch helps to conserve energy through methods such as Link Status and Cable Length Detection. The Link Status feature automatically powers down ports that have no link, allowing the switch to save substantial amounts of energy by cutting power for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjust power usage accordingly, helping you save energy without affecting networking performance. In addition, the fan-less design extends the switch’s life and also reduces noise.
General features
	KEY FEATURES
	• Five 10/100 Mbps fast Ethernet ports with one PoE enabled port
	• Auto MDI/MDIX Crossover for all ports
	• Store-and-forward Switching Scheme
	• Full/half-duplex for Ethernet/fast Ethernet Speeds
	• IEEE 802.3x flow Control
	• Plug-and-play Installation
	• Built-in D-Link green Technology
	• RoHS Compliant
	• IEEE 802.1p QoS (4 Queues, Strict Mode)
	SWITCHING CAPACITY
	1 gbps
	STANDARDS
	• IEEE 802.3 10BASE-T Ethernet
	• IEEE 802.3u 100BASE-TX fast Ethernet
	• ANSI/IEEE 802.3 NWay Auto-negotiation
	• IEEE 802.1p QoS
	POE FEATURES
	• Supports IEEE 802.3af
	• Supplies power to PD:  up to 15.4 watts
	• Total PoE budget: 15.4 watts
	• PoE port count/Average PoE watts
	DATA TRANSFER RATES
	• Ethernet:
	  10 Mbps (half duplex)
	  20 Mbps (full duplex)
	• Fast Ethernet:
	  100 Mbps (half duplex)
	  200 Mbps (full duplex)
	TOPOLOGY
	Star
	MEDIA INTERFACE EXCHANGE
	Auto MDI/MDIX adjustment for all ports
	NETWORK CABLES
	• 10BASE-T
	• UTP CAT 3/4/5/5e (100 m max.)
	• EIA/TIA-586 100-ohm STP (100 m max.)
	• 100BASE-TX
	• UTP CAT 5/5e (100 m max.)
	• EIA/TIA-568 100-ohm STP (100 m max.)
	LED INDICATORS
	• Per port: Link/Activity/Speed/PoE Status
	• Per device: Power/PoE Max
	TRANSMISSION METHOD
	Store-and-forward
	MAC ADDRESS TABLE
	2K Entries per device
	MAC ADDRESS LEARNING
	Automatic update
	PACKET FILTERING/FORWARDING RATES
	• Ethernet: 14,880 pps per port
	• Fast Ethernet: 148,800 pps per port
	RAM BUFFER
	64 KBytes per device
Certificates
Order info
DES-1005P/A1 5-port 10/100 switch with one PoE port
