Quick find
Product features:
xStack L3 Managed Fast Ethernet Switch with 48 ports 10/100Mbps, 2 ports 1000 SFP, 2 combo ports 1000BASE-T/SFP and Power Saving function
EOL
General features:
Interfaces
• 48 10/100BASE-T ports
• 2 1000 SFP ports
• 2 Combo 10/100/1000 BASE-T / 100/1000 SFP ports
Optional Redundant Power Supply
DPS-200
Console Port
RJ-45
Out-of-band Management
RJ-45
Performance
• Switching Capacity: 17.6Gbps
• 64-byte Max. Packet Forwarding Rate: 13.1Mpps
• CPU: 800MHz
• Packet Buffer: 3MB
• Flash Memory: 32MB
• DRAM: 256MB
Software Features
Standard Image Features
Stackability
• Physical Stacking
- Up to 1 Gbps Stacking Bandwidth
- Up to 8 units per stack
• Virtual Stacking
- D-Link Single IP Management (SIM)
- Up to 32 units per Virtual Stack
L2 Features
• MAC Address Table: 16K
• Flow Control
-802.3x Flow Control
- HOL Blocking Prevention
• Jumbo Frames up to 10,240 bytes
• Spanning Tree Protocols
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- BDPU Filtering
- Root Restriction
• Loopback Detection
• Ethernet Ring Protection Switching (ERPS)
• 802.3ad Link Aggregation
- Max. 14 groups per device / 8 ports per group
• Port Mirroring
- One-to-One
- Many-to-One
- Flow-based
- RSPAN
• L2 Protocol Tunneling
L2 Multicasting
• IGMP Snooping
- IGMP v1/v2/v3 Snooping
- Supports 1024 IGMP groups
- Port/Host-based Fast Leave
• MLD Snooping
- MLD v1/v2 Snooping
- Supports 1024 groups
• IGMP/MLD Proxy Reporting
VLAN
• VLAN Group
- Max. 4K VLAN groups
• GVRP
- Supports 4K dynamic VLAN groups
• 802.1Q Tagged VLAN
• Port-based VLAN
• 802.1v Protocol VLAN
• Double VLAN (Q-in-Q)
- Port-based Q-in-Q
- Selective Q-in-Q
• VLAN Translation for single/double tagged packets
• Voice VLAN
• MAC-based VLAN
• Subnet-based VLAN
• ISM VLAN
• VLAN Trunking
• Private VLAN
L3 Features
• Max. 256 IPv4 Interfaces, 32 IPv6 Interfaces
• ARP Proxy
• Loopback Interface
• IGMP/MLD Proxy
• VRRP
• IPv6 Tunneling
- Static
- ISATAP
- GRE
- 6to4
L3 Routing
• Up to 7,286 IPv4 external routes
• Up to 1,821 IPv6 external routes
• Up to 3,575 IPv4 host routes
• Up to 1,821 IPv6 host routes
• 256 static routing entries for IPv4, 128 entries for IPv6 2
• Policy-based Routing
• Route Redistribution
• RIP v1/v2
• OSPF
- Supports OSPF v2
- OSPF Passive Interface
- Stub/NSSA Area
- OSPF Equal Cost Route
L3 Multicasting
• Up to 1,024 hardware IPv4 multicast groups
• Up to 256 hardware IPv6 multicast groups
• IGMP Filtering
- Up to 60 IGMP fltering profles, 128 ranges per profle
- IGMP v1,v2,v3
- DVMPR v3
- PIM-DM
- PIM-SM
- PIM-SSM
- PIM Sparse-Dense Mode
QoS (Quality of Service)
• IEEE 802.1p
• DSCP
• 8 Queues per Port
• Queue Handling
- Strict Priority
- Smoothed Deficit Weighted Round Robin (SDWRR)
- Strict + SDWRR
• CoS based on
- Switch Port
- VLAN ID
- 802.1p Priority Queues
- MAC Address
- IPv4/v6 Address
- DSCP
- Protocol Type
- IPv6 Traffic Class
- IPv6 Flow Label
- TCP/UDP Port
- User-defined Packet Content
• Supports Following Actions for Flows
- Remark 802.1p Priority Tag
- Remark TOS/DSCP Tag
- Bandwidth Control
- Flow Statistics
• Three Color Marker
- trTCM
- srTCM
• Bandwidth Control
- Port-based (Ingress/Egress, Min. Granularity 64Kbps)
- Flow-based (Ingress/Egress, Min. Granularity 1Kbps)
- Per Egress Queue Bandwidth Control (Min. Granularity 64Kbps)
• Time-based QoS
Access Control List (ACL)
• Up to 1,024 Ingress Access Rules
• Up to 500 Egress Access Rules
• ACL based on
- 802.1p Priority
- VLAN ID
- MAC Address
- Ether Type
- IPv4/IPv6 Address
- DSCP
- Protocol Type
- TCP/UDP Port Number
- IPv6 Flow Label
• ACL Statistics
• Time-based ACL
• CPU Interface Filtering
• SSH v2
• SSL v1/v2/v3
• Port Security
• Broadcast/Multicast/Unicast Storm Control
• Traffic Segmentation
• IP-MAC-Port Binding (IPv4/IPv6)
- ARP Packet Inspection
- IP Packet Inspection
- DHCP Snooping
- IPv6 ND Snooping
- Supports up to 500 address binding entries per device
• D-Link Safeguard Engine
• NetBIOS/NEtBEUI Filtering
• DHCP Server Screening
• BDPU Attack Protection
• ARP Spooofing Prevention
• L3 Control Packet Filtering
AAA
• 802.1X
- Port-based Access Control
- Host-based Access Control
- Authentication Database Failover
- Identity-Driven Policy (VLAN, ACL, or QoS) assignment
• Web-based Access Control (WAC)
- Dynamic VLAN Assignment
- Identity-Driven Policy (VLAN, ACL or QoS) assignment
• MAC-based Access Control (MAC)
• Japan Web-based Access Control (Host-based JWAC)
• Compound Authentication
• Guest VLAN
• Microsoft®NAP
- 802.1X NAP support
- DHCP NAP support
• RADIUS
• TACACS
• XTACACS
• TACACS+
• RADIUS Accounting
• 3 Level User Account
• Trusted Host
Operation, Administration & Management (OAM)
• Loopback Diagnostic
• Cable Diagnostics
• 803.2ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Dying Gasp
• ITU-T Y.1731
Green Features
• Power Saving by Link Status 3
• Power Saving by Cable Length 3
• Power Saving by LED Shut-Off
• Power Saving by Port Shut-Off
• Power Saving by System Hibernation
Management
• Web-based GUI (Supports IPv4/IPv6)
• Command Line Interface (CLI)
• Telnet Server (Supports IPv4/IPv6)
• Telnet Client(Supports IPv4/IPv6)
• TFTP Client(Supports IPv4/IPv6)
• FTP Client
• Remote Copy Protocol (RCP)
• PPPoE Circuit-ID Tag Insertion
• ZModem
• SNMP v1/v2c/v3
- SNMP over IPv6
• SNMP Traps
• System Log
• SMTP
• RMON v1
- Supports 1,2,3,9 groups
• RMON v2
- Supports ProbeConfg Group
• sFlow
• LLDP
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay (Support IPv4/IPv6)
• DHCP Relay Option 60, 61, 82
• DHCP Server
• Flash File System
• Multiple Images
• Multiple Configurations
• CPU Monitoring
• DNS Relay
• SNTP
• Password Recovery
• Password Encryption
• Microsoft® NLB (Network Load Balancing)
• Ping (Supports IPv4/IPv6)
• Traceroute (Supports IPv4/IPv6)
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC 1901-1908, 1442, 2578 SNMPv2 MIB
• RFC1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC2674, 4363 802.1p MIB
• RFC2233, 2863 Interface Group MIB
• RFC2925 Ping & Traceroute MIB
• D-Link Private MIB
• RFC2787 VRRP MIB
• RFC1724 RIPv2 MIB
• RFC1850 OSPF MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 IP Forwarding Table MIB
Standard Compliance
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC793 TCP
• RFC826 ARP
• RFC1321, 2284, 2865, 2716, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571 SNMP Framework
• RFC2572 SNMP Message Processing and Dispatching
• RFC2573 SNMP Applications
• RFC2574 User-based Security Model for SNMPv3
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC3513 IPv6 Addressing Architecture
• RFC2893 IPv4/IPv6 dual stack function
• RFC3056 IPv6 Tunneling
• RFC2328, 3101 OSPF
• RFC1112, 2326, 3376 IGMP
• RFC3973 PIM-DM
• RFC4601 PIM-SM
• RFC3569 PIM-SSM
• RFC1112, 2236, 3376, 4605 IGMP Proxy
• RFC4541 Proxy Reporting
• RFC4363 802.1v
• RFC1027 ARP Proxy
• RFC2338 VRRP
• RFC1058, 1388, 1723, 2453 RIP
• RFC2475 Priority Queue Mapping
• RFC2475, 2598 Class of Service (CoS)
• RFC2597, 2598 QoS Flow Actions
• RFC2697, 2698 Three Color Marker
• RFC2246 SSL
• RFC3580 802.1X
• RFC2866 RADIUS Accounting
• RFC2138, 2139, 2865, 2618 RADIUS Auth for Mgmt Access
• RFC1492 TACACS+ Auth for Mgmt Access
• RFC2068, 2616 Web-based GUI
• RFC854 Telnet Server
• RFC1519 CIDR
• RFC 2474, 3168, 3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC783, 1350 TFTP Client
• RFC1157, 1901, 1908, 2570, 2574, 2575 SNMP
• RFC3164 System Log
• RFC2819 RMON v1
• RFC3176 sFlow
• RFC951, 1542, 2131, 3046 BOOTP/DHCP Client
• RFC2131 DHCP Server
• RFC1769 Time Setting
• RFC2821 SMTP
• ITU-T Y.1731
• ITU-T G.8032
• IPv6 Ready Logo Phase 2 router mode
Enhanced Image Features
• Advanced L3 Routing
- BGP v4 2
• IPv6 Dynamic Routing
- RIPng
- OSPFv3 2
• MPLS
- LDP
- MPLS Label Management
- VPWS
• Management
- Switch Resource Management (SRM)2
MTBF (hours)
375,189
Acoustic
< 33°C: 32.6dB
> 33°C: 42.3dB
Heat dissipation
123.78BTU/h
Power Input
100 to 240VAC, 50 to 60Hz Internal Universal Power Supply
Max Power Consumption
38.8 watts
Dimensions
441 x 309 x 44mm
Weight
4.1kg
Ventilation
1 Smart Fan(Default low speed)
Operating temperature
0° to 50°C
Storage temperature
-40° to 70°C
Operating humidity
10% to 90% non-condensing
Storage humidity
5% to 90% RH
Emission (EMI)
FCC Class A, CE, C-Tick, VCCI
Safety
cUL, CB
Certifications
Products | Support  | News  | About |
